I noticed no "suction" at return vent in hall at main level.
Closer look at HVAC unit in lower level utility room I find return duct is open at top, only source for return air in 2 level 2800 sq. ft. house. Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
| Need a home inspection in Texas? Check out InterNACHI's listing of Texas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
WOW,that sucks......er actually I mean it doesn't.
Here is mine from yesterday that sucked. ![]() Bonus points to first that guess blue metal function sitting on top of filter. |
Wow that's a little dangerous seeing that it's open to the combustion zone.
Actually the cover was from the old one but the other side had fiberglass insulation on the b vent wrapped with electrical tape.
In my opinion as a professional and competent home inspector the return air configuration for the HVAC system is inadequate. The only air return source is at return plenum in utility room, at ceiling level. I recommend having a professional HVAC technician inspect further and repair as needed.
I went the other route and stated...... • The return has a vent opening in thefloor directly in front of the unit and should be sealed as this could pull in carbon monoxide fumes which would then circulate throughout the household. Had to get home to look at the report Charlie.Though I could have pulled it off Dom's upload service on the phone I suppose. |
The return is within 10 feet of the combustion chamber (for you code nuts)...
Here's one for you. Is CO lighter or heavier than air? "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
CO is lighter than air....
Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
Slightly lighter than air.
"Carbon monoxide has a molar mass of 28.0, which makes it slightly lighter than air, whose average molar mass is 28.8." http://en.wikipedia.org/wiki/Carbon_monoxide “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Did they have this set up as a wild return. Did you by any chance check the static pressure to see if it was with the range
www.tristatehomeinspections.org www.tristateenergyinspections.com If you always do what you always did you will always get what you always got. |
How far from Home Inspection is that?! OK, as for the "specific gravity" of CO vs. Air; if it were heavier than air, would it still not rise? Yes-No? Why? "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
| Pellet stove help | chellickson | General Inspection Discussion | 23 | 8/19/10 1:23 AM |
| vent pipe in return | dlee2 | Inspecting HVAC Systems | 2 | 2/18/10 12:51 PM |
| Gas and oil hot water tank and Boiler Share Vents | hvanderbeek | Miscellaneous Discussion for Inspectors | 8 | 1/25/07 5:22 PM |
