Is there some thing wrong with this pic? The exhaust pipe runs 4” above the top of the panel. The exhaust flue blocks the path that the make up air supply pipe should run.
Kenneth Sitzes NACHI #04122492 Eagle Inspection of Illinois 618-830-8283 Waterloo, Illinois 62298 ghinspector@yahoo.com InterNACHI State of Illinois Continuing Education Administrator |
That depends if the intake is going to be hooked up.
Where is the unit located? In a conditioned space? |
In the basement.
Is the basement finished?
Yes, then it should be piped. No, it is a general rule that open basements are unconditioned spaces and the make up air in not required if the sq. ft. area is sufficient to provide this air. |
| Do you put polybutylene in the Summary? | jfunderburk | Plumbing Inspections | 36 | 10/27/10 11:21 AM |
| Help - Polybutylene Pipes | Rick G | Plumbing Inspections | 39 | 2/12/09 9:16 AM |
| Identify ABS defective pipe | mcyr | Plumbing Inspections | 6 | 1/29/09 7:39 PM |
| Electrical ground across water meter to plastic supply pipe? | gliebig | Electrical Inspections | 9 | 12/19/06 10:30 PM |
| Help Identifying Water Supply Pipe | Steven Brewster | Plumbing Inspections | 3 | 4/25/06 1:32 AM |
