In the summer when the A/C is going full blast does anyone test the performance of the heater, and visa-versa for the winter time?
I don't, and disclose it as it would be harmful to the unit to do so, but I get some buyers who really want me to crank up the heat to make sure it works. So far I haven't had anyone push the issue, have you? Eric W. Augustin A1 Certified Home Inspections If you can't explain it simply, you don't understand it well enough. Albert Einstein
| Need a home inspection in Delaware? Check out InterNACHI's listing of Delaware certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I always test the heat in the summer. Turn the AC off, turn the fan "on" for about 15 minutes until the coils reach ambient temperature. Turn on the heat and test the heat at one register. Reverse the process (turn the heat off, leave the fan on). When the coils are back at ambient temperature, turn the AC back on and check each register for cooling and air flow.
I don't test the AC when the exterior temp is below 65. "A man cannot be truly grateful and remain unhappy"
http://www.SmithHomeInspection.com SmithHomeInspection@yahoo.com NY State Lic. # 16000008304 631-434-5200 |
Bobby Hamilton Bloodhound Home Inspection Services Youngstown Home Inspection Austintown Ohio Home Inspection Providing home inspections, state licensed termite inspections and radon testing in Youngstown, Boardman, Canfield, Poland, Howland, Warren and surrounding Northeast Ohio areas.
Are you guys talking about heat pumps? Or electric A/C and gas heat.
Mine was an oil fired furnace with the AC air handler in it.
BPI Certified Professional Building Analyst BPI Certified Envelope Professional Infraspection Institute Certified Level II Thermographer # 8510 www.dapkusinspections.com www.chicagoinfraredthermalimaging.com www.mychicagohomeinspector.com www.commercialbuildinginspectionchicago.com Professional Infrared Network Chicago Energy Audit Aerial Infrared Inspection Certified Infrared Thermal Imaging |
It is a heater for crying out loud. How are you going to hurt it by making it operate using normal operating controls. It is designed to get hot...very hot. If you have ever been to a little old ladies house in winter you would know you can't hardly overtax one. Most of them have it set for for like 95 F and it is like a slag furnace inside the home. Even the dog and cat are begging to be put down and out of their misery.
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill |
I'll agree if you shut the A/C off and allow sufficient time for it to acclimate to the surrounding room temperature, it should not harm the unit, but to turn it from A/C running at 72 degrees to heat at 90 degrees in one flip of the switch is not good for the unit (or so I've been told).
Maybe I'm wrong on this and will do further research. I know I won't do that to my unit. Eric W. Augustin A1 Certified Home Inspections If you can't explain it simply, you don't understand it well enough. Albert Einstein
Please do but do not ask your next door neighbor or your brother- in- law they don't have the correct answer ????? If that bothers you as someone mentioned above just leave the blower operating for 5 minutes after you shut the A/C off and it brings the A-coil to the return air temp????
Are you just being an a s s hole? Or is this the way you are?
I typed out a response to this crap and deleted it. We have been through this too many times already... The main point IS (and take this to your research endeavor), you can run an oil, gas, electric and heat pump in the heat mode (without "taking a break") regardless of all the stupid crap you have read, because people much smarter than your sorry *** took the time to put safety controls in the equipment design so dumb asses "CAN'T" do stupid crap to the unit and break it. If you don't agree, if they didn't kick out everyone yet that actually know this crap because they didn't take the boyscout class that we do not agree with and must answer the question "WRONG" to PASS...; ask them... "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
I'm pretty much an a s s hole, thanks for asking.
My biggest mistake was to bring an honest question to the message board and expect a real answer without the arrogance, ego's, belittling responses. Now I see why InterNACHI boasts over 8000 members, but only 500 or so come here... Eric W. Augustin A1 Certified Home Inspections If you can't explain it simply, you don't understand it well enough. Albert Einstein
You ask a question and fight the replies...
If you don't like it, join the ranks... If you looked (during your research) this has been covered several times. Many think like you and pass on the wrong information to their clients. If your "all-knowing" brother-in-law was so damn smart why are you wasting our time? "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
| Mold Inspectors in Coeur d’Alene, ID 83815 | rspriggs | Ancillary Inspection Services & Additional Topics | 15 | 1/3/12 1:14 PM |
| Washington State Inspectors - Your Deadline Is Near | Mike O'Handley | Legislation, Licensing & Legal Issues for Inspectors | 54 | 4/14/10 9:15 PM |
| Well Water Testing in Coeur d’Alene, ID 83815 | rspriggs | Ancillary Inspection Services & Additional Topics | 0 | 1/9/09 3:31 AM |
