Old 6/13/09, 5:35 PM
kcheng kcheng is offline
Default Oil boiler combined w/ water heater?
Hello all, I just recently did an inspection and thought I should post something interesting here..it's an american standard oil boiler, it's also act as a water heater, so two units in one, there's also no service tag on here w/ the barometric damper not freely moving...anyone seen this before? any thoughts?
Find an InterNACHI certified Minnesota Home Inspector (and anywhere else in North America)
Old 6/13/09, 6:25 PM
Wayne B. Wilson's Avatar
Default Re: Oil boiler combined w/ water heater?
by no service do mean do not use service?
Btw did you see a tprv on it i cant see by the picture.
Also the damper should be straight it is sloping in a downward slope
By the amount of rust in the sight glass it needs service .
Oh yeah where was the expansion tank ?
Old 6/13/09, 10:41 PM
thanks for the comments Wayne...by no service it means that there's no service tag, I believe the unit should be service on an annual basis...you're right, there's no TPRV, with the sloped damper, I noted that it doesn't operate freely, but not sure about the downward sloping, there's no expansion tank because it's a steam system
Old 6/13/09, 10:56 PM
the damper should be level or it will not operate the way it should Kinda of a balance thing
Old 6/13/09, 11:08 PM
I know ther has to be a low water cut off somewhere but i do not see it but with the rust in the sight glass i would say it needs to be drained and flush a few times . I do not suppose they have a chemical feed on it either . I thinking it really need attention.
Old 6/14/09, 6:31 AM
John Evans John Evans is offline
The sight glass indicates this is a steam system. The expansion tank in older homes may have been located in the attic. Here is a good article regarding steam systems.
http://www.inspect-ny.com/heat/Steam..._Controls1.htm
[Maryland Home Inspections
www.aimhomeinspection.com
Infraspection Certified Level 1 No. 7801
Old 6/14/09, 7:17 AM
David P. Valley's Avatar
I see boilers every day.
This is an older boiler (40+ years) with a tankless domestic hot water supply.
It simply needs servicing.
Old 6/17/09, 7:12 PM
David P. OKeefe's Avatar
David P. OKeefe David P. OKeefe is offline
Here is a picture of an expansion tank for a boiler I found in an attic. The iron pipe is a vent/roof drain. Here's a pic of the boiler.
oil-boiler-combined-w-water-heater-179-400.jpg   oil-boiler-combined-w-water-heater-120-400.jpg
David
InterNACHI #08051301
NYS Lic. #16000038229
NYS DEC Cert # T4865884
518-505-8305
HouseAbout Home Inspections
HouseAbout on Facebook
NY Capital Region Chapter InterNACHI
Old 6/18/09, 6:44 AM
Don't you just love those asbestos covered antiques?
flammable vapor ignition resistant dbaucum General Inspection Discussion 35 2/19/08 1:42 PM
Water Heater Dip Tube Failure jacaron Plumbing Inspections 2 2/24/07 11:28 PM
Hot Water Heater djohnson6 Plumbing Inspections 12 12/28/06 9:18 PM
Need Help On Chimney Liners Nick Scibetta Exterior Inspections 13 1/11/06 9:53 PM
