Old 1/23/08, 6:28 PM
nbhi's Avatar
nbhi nbhi is offline
Default Oil Cumsumption?
Had a past client call with a concern on the consumption of fuel oil for a:
The model is a lennox elite
model num. OHR23Q3/4-105/120-6C
ser num. 8406A00078
They said they went through 125 gal. in one month, never before did they come this close. Furnace will run for 10 min. shutdown then 45 min before it cycles again. Any ideas? Thanks
"I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison
www.newbeginningshomeinspection.com
Old 1/23/08, 6:54 PM
Jeffrey S. Campbell's Avatar
Jeffrey S. Campbell Jeffrey S. Campbell is offline
Send a message via AIM to jcampbell Send a message via MSN to jcampbell Send a message via Yahoo to jcampbell
Default Re: Oil Cumsumption?
you might suggest they try checking with the oil company to track the degree days they recorded during that period... some track it to compare usage, they can compare one year or month to the next. Here in Maine we has some really cold periods... over a month straight below freezing... the units got a workout...
other than that as long as they've had the unit serviced regularly... filters replaced... balanced ducts... just some thoughts...
Jeff Campbell
Campbell Property Inspections
http://www.maineshomeinspector.com
Pittston, Maine
NACHI04013010
Old 1/23/08, 7:05 PM
David P. Valley's Avatar
ser num. 8406A00078
You got an obvious cycling issue that is most important right now. The unit is only two years old.
Have them open the lower cover, and observe the computer board that is attached in the plenum somewhere. When the unit is shut down, there should be a flashing light that is flashing a "code". See how many times that light flashes, and then remove the lower sheet metal panel covering that board. On the inside of that cover there will be a sticker that states what that blinking code means.
That is a starting point.
Old 1/23/08, 7:21 PM
Marcel Gratton's Avatar
ser num. 8406A00078
They have to keep the door/windows closed in winter...
On The Level Inspection
Gatineau, Québec
Old 1/23/08, 7:56 PM
Hey Marcel;
I tried that and the Go darn thing does not want to stop. I guess 5 degrees and bring that up to 68 degrees, cost money.
When it is cold, it is cold, and the furnace will try to maintain all the heat loss that we have in the house.
So all we can do is service our furnaces once a year and hope that it is in the 85% efficiency range and hope for the best.
All I can say is that the Arabs will make money this Year.
Marcel
</IMG>
Old 1/25/08, 8:14 AM
Gary Reecher Gary Reecher is offline
Send a message via Yahoo to Gary Reecher
Please Note: Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
You did not state the fuel tank and line locations. Indoor tank or outdoor tank? Exposed fuel lines or buried fuel tank and lines?
If they have a buried tank and fuel lines they may have a tank or line leak if so they have a major clean up to do besides replacing the tank and or lines.
Old 1/25/08, 8:18 AM
Also
Old 1/25/08, 8:21 AM
Originally Posted by mcyr
Hey Marcel;
Marcel
</IMG>
As well as the US Guvnment tax coffers. They sure do tax alot on something they don't even produce.
Old 1/25/08, 10:57 AM
Doug Edwards,  CMI's Avatar
I would have told them to call a repairman. Oil or fuel consumption of any kind is outside the area of responsibility for a HI. It is obvious the furnace had performed normally prior to this one month based on the statement. If you are not careful past clients will try and make you their go to guy anytime something goes wrong in an effort to get some free service. I have had them call me a year after an inspection to tell me their AC just quit...."What do I do?" I tell them to do what I do, call my HVAC guy. We all need to learn to take our own advise. Helping with general information w/o putting ourselves in a liability situation is fine, but free troubleshooting over the phone could have dire consequences.
Old 1/27/08, 1:25 PM
Charles Jones Charles Jones is offline
Please Note: Charles Jones is a non-member guest and is in no way affiliated with InterNACHI or its members.
GOOD aDVICE
Old 1/28/08, 2:00 PM
David A. Andersen's Avatar
Do the math!
Determine the Btu/gal of the heating oil and compare it with the heat load of the house.
Then call the HVAC guy. Oil burners are finicky and must be tuned up annually (at least a filter and nozzle change).
Old 1/28/08, 4:03 PM
Banned
ser num. 8406A00078
If the furnace runs that little on cold days and there are no comfort issues, they should be very happy. The unit (or nozzle) may be oversized for the space to be heated if it runs that little. That is a bit of a design flaw from the beginning and contributes a bit to overall inefficiency of the system. If a house heat loss calculation was done for the local design temps and the unit sized accordingly, it should run 40-45 minutes on the colder days with temps at or close to design. It will run longer per hour but will have a much smaller nozzle and there should be some overall savings.
Old 1/28/08, 4:23 PM
Banned
Originally Posted by dandersen
Do the math!
I recommend that it be based on yearly historical records of the oil use versus the degree days for that year (if nothing has changed in the house or no one moved in, new baby,etc) I find that more accurate than some of the energy audit/heat loss programs in use.
and a cleaning..... and efficiency/smoke/draft tests .... and a test of the safety controls (high temperature limit and flame-out controls,) .....and test fuel pump pressure and .......check the fire chamber and ......adjust the barometric damper, if installed. Many of these things are not done in my area although the CSA standard referenced by the code here calls for these with every servicing!!!!
Old 1/28/08, 5:04 PM
Yea, that's what I said; "A tune up"!
