What do YOU guys inspect when looking at an oil fired furnace and water heater?
It is a buried tank. Thanks |
I usually start with the storage tank ( rusty?..especially the bottom?), if visible, and follow the line(s) to the furnace noting condition (rust, damage, protection, etc.), shut off valve, filter, etc.
Check adequate venting for combustion air, oily smoke (soot) or smells at the unit, firebox port, top of chimney and barometric damper. Check for damaged or deteriorating firebox lining. Other than bright orange or yellowish white flames is an indication of inefficient combustion. Check for excessive noise or vibrations, draft spillage, clearances and proper chimney and piping. Really, oil furnaces need service annually so I recommend that too. Here is some info on tanks: http://www.inspect-ny.com/oiltanks/fueltank.htm http://www.doityourself.com/stry/oilfiredfurnace |
As to the burried tank, you have to recommend specialist evaluation of that component as so many of those are failing. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
| MSFH - Home Inspector Fired In Dispute Over Pay | jburkeson1 | General Inspection Discussion | 27 | 5/1/09 2:55 PM |
| Wood Fired Boiler (Exterior) | jhagarty | Inspecting HVAC Systems | 7 | 11/8/07 8:02 AM |
| Gas Fired Furnace's Electrical Question. | pdoane | Inspecting HVAC Systems | 19 | 6/20/07 8:34 AM |
| Gas fired | pjcloninger | Inspecting HVAC Systems | 2 | 10/7/06 12:43 AM |
