Old 10/27/11, 10:20 AM
Frank L. Bartlo Frank L. Bartlo is offline
Question Oil leakage observed at AC coolant line at bonnet -- too cold to run unit
Came across something a bit puzzling in last evening's inspection I've not encountered before.
The house had a relatively old AC condenser (evidently manufactured in 1987 per serial # and style, round Comfortmaker design as common around then), and the outside air temperature was about 50F, too cold to run it. The fan blade turned easily when pushed with a twig.
When looking at the furnace/blower unit, I noticed what looked like a water spot on the floor that turned out to be some sort of oil, which I then saw was dripping from the coolant line where it exited the bonnet.
So, my questions for AC specialists:
What's going on here?
Does this have any implications regarding the performance of the unit?
I intend to report the unit as more-or-less at the typical life expectancy of such a unit and likely to be considerably less efficient than a more modern unit, and recommend a servicing checkup by a licensed specialist anyway, but I am curious as to the significance, if any, of this.
oil-leakage-observed-ac-coolant-line-bonnet-too-cold-run-unit-20111026-190_197_1b.jpg   oil-leakage-observed-ac-coolant-line-bonnet-too-cold-run-unit-20111026-191_198_1tb.jpg   oil-leakage-observed-ac-coolant-line-bonnet-too-cold-run-unit-20111026-189_196_1rt.jpg
Need a home inspection in Michigan? Check out InterNACHI's listing of Michigan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/27/11, 10:57 PM
Charley L. Bottger's Avatar
Default Re: Oil leakage observed at AC coolant line at bonnet -- too cold to run unit
Frank I would like to help you get your terminology going in the right direction I don't understand what you are calling a bonnet in the pic I see the suction and liquid refrigerant lines entering and exiting the A-coil plenum box. And to answer your question yes if there is refrigerant oil dripping from the line set which also means that refrigerant is also leaking from the system and the unit would not function properly. The remaining refrigerant if any would be required to be pumped down and retained in the exterior condensing unit. The leak on the suction line repaired, a vacuum pulled on the line set and the A-coil and the system re-charged with refrigerant. In Oklahoma that would be approximately $350.00 repair job. Ca about $650, If a NY engineer repaired the leak cost would be about $850.00
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 10/29/11, 4:36 PM
Try a little more explanation with clients.
We were unable to inspect the cooling system due to the cool 50 degree outside air temperature (industry standards state operating an A/C unit below 60 degrees can potentially damage a compressor). We also noted the unit was approximately 23-24 Years old +/-. Units like this typically have a normal life-span of 8-15 years. We also noted an oil like substance on the freon lines (possible sign of past or present freon leakage).
We recommend having a licensed and competent HVAC contractor service the unit, leak check coils, check freon levels, and the proper operation of the unit prior to close.
Old 10/30/11, 9:38 AM
Robert J. OConnor's Avatar
... and budget for replacement due to the age.
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
What is your HVAC procedure? sstowe Inspecting HVAC Systems 66 5/28/09 12:48 PM
TPRV line and condensate line marriage ccarrington Plumbing Inspections 3 4/29/06 7:59 AM
