Old 2/18/09, 8:42 PM
nbhi's Avatar
nbhi nbhi is offline
Default Oil tank
What type of inspections, if any are any of you doing for fuel oil tanks for furnaces? Todays inspection has one that is underground. Not much to see from this view point.
"I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison
www.newbeginningshomeinspection.com
Old 2/18/09, 9:07 PM
Default Re: Oil tank
Underground tanks don't last long, ten years or so. Above ground can be double that probably less.
Here's a good checklist:
http://www.inspect-ny.com/oiltanks/tankinsp.htm
More info:
http://www.inspect-ny.com/oiltanks/tanks.htm
Larry Kage, CMI
231 929 3525
Water heater expansion tank jfrederick Plumbing Inspections 3 11/17/08 3:35 PM
Water heater expansion tank jfrederick Plumbing Inspections 0 11/17/08 8:18 AM
Subject: Safety Flash: Propane Tank Danger ksitzes Miscellaneous Discussion for Inspectors 1 6/2/08 12:04 PM
Oil Tank in Basement Bedroom! csteele Inspecting HVAC Systems 18 10/23/06 8:25 AM
