Old 1/6/06, 9:21 PM
ecox1's Avatar
ecox1 ecox1 is offline
Send a message via Yahoo to ecox1
Default oil tank
can anyone explain this oil tank. Is it suppose to be out in the open
Old 1/6/06, 9:33 PM
Default Re: oil tank
It stores and supplies oil to the furnace.
Old 1/7/06, 10:08 AM
Steve McIntire's Avatar
Steve McIntire Steve McIntire is offline
Earl, I do not want to write anything that would keep you from posting and asking questions, because that is what this board is great for.
The tank in the picture does not look to be that old. Did you inspect the furnace at this home and how did you report on it? Did you follow the line from the tank to the furnace?
I would recommend taking some classes or do some reading on oil-burner type furnaces. These units are different than your normal forced air furnace.
I hope this helps, and I hope you understand this post is supposed to be positive.
Old 1/7/06, 10:14 AM
jrivera's Avatar
jrivera jrivera is offline
Please Note: jrivera is a non-member guest and is in no way affiliated with InterNACHI or its members.
Originally Posted by ecox1
can anyone tell me what is this oil tank used for.
Hey, whats up, why ya asking ? Is there something else about this house that we can't see ?
Mickey
Old 1/7/06, 11:27 AM
cmccann's Avatar
cmccann cmccann is offline
Please Note: cmccann is a non-member guest and is in no way affiliated with InterNACHI or its members.
Oh it's old, the tank just has a fresh coat of paint. Earl, have you taken any inspection classes?
Old 1/7/06, 11:47 AM
Kevin P. Williams's Avatar
Kevin P. Williams Kevin P. Williams is offline
Earl, what are those 3 wires in photo ??
Old 1/7/06, 12:52 PM
Russel Ray's Avatar
Oil-burning furnaces?
No wonder why the price of gas is so high.
Old 1/7/06, 11:06 PM
Jay Moge's Avatar
Jay Moge Jay Moge is offline
those wire look like cable coax or satalite (unit to right has a dish). and the sending unit (where supply and return acces tank) appears to have some welding done on it after it was painted. or just concentrated currosion. hard to tell from just one pick.
Old 1/8/06, 7:27 AM
3 wires for a dish ??
Old 1/8/06, 9:25 AM
twheeler
Guest
Posts: n/a
Here's how an "oil" tank should be installed. Otherwise there will be problems.
Figure 1: Typical Outside Tank Installation
  1. Stable base (ex. poured concrete slab or reinforced patio stones).
  2. Manufacturer’s label, with UL standard or code.
  3. Horizontal loop (sloped down) in oil feed line to allow minor tank movement.
  4. Install a guard to protect oil feed line.
Old 1/8/06, 1:03 PM
ecox1's Avatar
The reason I ask is this is the first oil burning furnace I've seen.
Old 1/8/06, 1:03 PM
ecox1's Avatar
Yes the wires are coming from a sat. dish
Old 1/8/06, 1:05 PM
ecox1's Avatar
Ok maybe I post my question in the wrong way
Old 1/8/06, 1:31 PM
Joseph Hagarty,  CMI's Avatar
I generally recommend containment and weatherproof covering when tanks are found in an exterior enviroinment.
http://www.granbytanks.com/eng/containment_cover.shtml
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 1/8/06, 1:38 PM
Joe Hagerty--Now I like that tank-box or whatever it is.
Around here the tanks have an insulated structure of plyboard
built around them. Some are a real bear to service.
Wow fduemig Miscellaneous Discussion for Inspectors 4 6/13/07 8:00 AM
Buried Oil storage tank brepanshek Inspecting HVAC Systems 6 1/29/07 10:07 PM
Oil Tank in Basement Bedroom! csteele Inspecting HVAC Systems 18 10/23/06 8:25 AM
Expansion Tank Question cpetty Plumbing Inspections 9 9/25/06 7:13 PM
Septic tank inside home mmorgan Plumbing Inspections 20 9/7/06 10:58 PM
