Old 3/26/08, 11:07 PM
Jeffrey S. Campbell's Avatar
Jeffrey S. Campbell Jeffrey S. Campbell is offline
Send a message via AIM to jcampbell Send a message via MSN to jcampbell Send a message via Yahoo to jcampbell
Default Oil tank... pad required?
new construction... oil tank in partial basement... crushed rock floor...
does this need a pad similar to a pad? NORA leads me to believe it should... be on some type of pad or secondary containment... as well as at least 6" above grade...
here is a photo...
Jeff Campbell
Campbell Property Inspections
http://www.maineshomeinspector.com
Pittston, Maine
NACHI04013010
Old 4/8/08, 8:47 AM
Charles Jones Charles Jones is offline
Please Note: Charles Jones is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Oil tank... pad required?
any tank feet I would want concret pads. what I see there the feet could start to sink in time and creat a hazard. exact code someone would have to answer for im just a hvac owner.
Old 4/8/08, 8:52 AM
that makes sense too... i was thinking leaking wise as well...
Jeff Campbell
Pittston, Maine
NACHI04013010
Old 4/8/08, 10:10 AM
jking2 jking2 is offline
Yes, it should have secondary containment, and it could possibly have it in the form of double wall construction, but we can't determine that from the photo.
Jim King
Old 4/8/08, 1:52 PM
Dennis R. Goudreau Dennis R. Goudreau is offline
IRC 2006
m2201.2, above groung tanks-- the maximum amount of fuel oil stored above ground or inside a building shall be 660 gallons, the supply tank shall be supported on rigid nocombustible supports to prevent settling or shifting
Old 4/8/08, 3:11 PM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
Are the feet set in concrete below the gravel? I think I would have moved some of the gravel and taken a pic of what it was sitting on. Can't really tell from the pic you posted. Personally, I agree I wouldn't like that sitting there from what I can see.
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Old 4/8/08, 5:14 PM
David P. Valley's Avatar
I agree. Most oil tanks are on concrete floors, But.....
I'd want to see what's supporting those legs. If they are encased in footings, it would be fine.
The gravel will keep the belly from getting moist and rusting.
The only downfall to this install is not being able to view the belly for it's present condition.
Oil Tank in Basement Bedroom! csteele Inspecting HVAC Systems 18 10/23/06 8:25 AM
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 5:58 PM
Emergency Lighting (commercial) mcyr Electrical Inspections 24 6/10/06 10:06 AM
