Mel Olinsky is a non-member guest and is in no way affiliated with InterNACHI or its members.
I just had a my condenser and evaporator coil replaced. The system appears to be cooling fine. But I noticed some water collecting just below the valve where the copper lines connect to the condenser unit outside. When I wiped it up, it felt oily. Is this an indication of a leak?
If you just recently as you stated had the unit worked on there can be oil on the valves from removing the gages if the service Tech did not use gages with check valves on the end of his hoses as required by the EPA. Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
Oily residue on lines can come from a couple of different things. The question I have is on what line did you find this stuff or was it on both? An oily residue on a suction line could be a leak that is drawing compressor oil through a pin hole leak. Why did you have to replace the condensing unit an the evaperator coils? If it was because of a burn out...there could have been compressor oil that leaked out and the tech might have just reused the existing lines. If that is the case...you should have an acid check done to make sure the lines were properly evaporated. The other thing I can think that would cause an oily residue would be residual soldering flux. HVAC lines should be silver soldered which is a little different from the kind of solder that most people are used to seeing in plumbing applications. Residual silver solder flux (if done correctly) usually dries to a hard finish that almost looks like shalac. If the tech was inpatient and didn't wait for the different phases for the flux to change colors and soldered the joint too soon...I could see that the flux would be a little oily if it got wet from condensation on the lines. There could be a lot of different things oil could come from on an AC compressor. Could even be something as simple as WD 40 from the tech trying to unscrew a valve stem cap (BIG NO NO). Best thing to do is call the company back up and request for a different tech than the one who installed the unit. The EPA has some pretty strict guidelines as to what needs to be done when a system has major service work like that done and if a tech screwed up...he's not going to admit it most of the time since they can be fined pretty harsh.
Hope I could shed a little light on your question. Scott Gilligan 215-888-4943 Infraspection Institute Level III Certified Thermographer Philadelphia Mold Inspections Philadelphia Home Inspections Philadelphia Commercial Inspections Philadelphia Licensed Home Inspector Pennsylvania - New Jersey - Delaware Infrared Thermal Imaging Inspections President The Greater Philadelphia Chapter of InterNACHI http://pa.nachi.org/greaterphiladelphia Vice President & Webmaster National Association of Commercial Building Inspectors and Thermographers |
| What is a 'condenser' dryer ?? | rcooke | Canadian Inspectors | 8 | 9/9/07 8:02 PM |
| TPR valve | acox | Plumbing Inspections | 19 | 5/27/07 1:36 PM |
| Backwater valve in new homes? | ccrooker | Canadian Inspectors | 16 | 11/28/06 8:47 AM |
| Tankless and TRP valve | jtroth | Plumbing Inspections | 14 | 8/8/06 1:09 PM |
| TRP Drain Line Question | psmothers | Plumbing Inspections | 22 | 7/6/06 5:57 PM |
