The exterior cap & liner looked good.
My question is where the furnace at water heater connect before they enter the chimney. Is there potential for the larger furnace flue to back draft thru the water heater flue? Furnace was installed 15 years ago. I would imagine this is when the liner was installed. Probably not the best idea to paint the flue piping. |
scosta is a non-member guest and is in no way affiliated with InterNACHI or its members.
Dave,
The first picture is a problem, the hot water tank should vent above the furnace. Yes there is the potential for back drafting.] Picture 2, if I am looking at it from the top of the chimney down, the vent connector extends too far into the chimney, and looks like its pointed down. Either way proper venting may be prevented. Steve |
The potential for back draft does exist also improper Tee we refer to that as a Bull headed Tee and in your pic it is backward
| Chimney flashing photo's needed: brick and stone done correctly | kshepard | Exterior Inspections | 6 | 10/13/07 9:10 AM |
| Floating Chimney Syndrome | mcyr | General Inspection Discussion | 8 | 7/25/07 12:49 AM |
| Fireplace Enclosure | jpope | Interior Inspections | 19 | 10/25/06 6:08 PM |
| Chimney Liner | dmacy | Inspecting HVAC Systems | 2 | 6/17/06 9:29 PM |
