Old 11/5/10, 2:43 AM
David Nasser's Avatar
David Nasser David Nasser is offline
Default Older ducting..good air flow...question
Home built in the 1960's, at some point central air was put in.
The ducting is of older style materials. Do I recommend a licensed
HVAC contractor to evaluate ? There is Good air flow at all the registers.
David
Need a home inspection in Indiana? Check out InterNACHI's listing of Indiana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/5/10, 9:02 AM
Joshua L. Frederick Joshua L. Frederick is offline
Default Re: Older ducting..good air flow...question
Evaluate what?
Old 11/5/10, 9:24 AM
Charley L. Bottger's Avatar
David
As a Hi hired to perform a visual inspection I don't use the word Evaluate in my reports I write what I see as wrong.
If the joints were leaking air that would be on the repair list If the ducts were not insulated as required for a non-conditioned space that would be on the repair list. Does not matter when A/C was added to the system it was always required to insulate ducts.
I see a lot of older duct work that had central heat only in its original conception and has just the fiber glass wrap no vinyl or paper outer wrapping I don't put that on the repair list but I do make a recommendation to upgrade to conserve energy
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Wall heater older home....ducting question dnasser Inspecting HVAC Systems 1 9/21/10 12:48 PM
Good test question for CMI cbottger Inspecting HVAC Systems 24 6/14/07 10:28 AM
Good advise on why NOT to discount. gmendes Miscellaneous Discussion for Inspectors 5 11/3/06 9:40 AM
