Old 2/13/08, 10:25 PM
John W. Springstead's Avatar
John W. Springstead John W. Springstead is offline
Default One flue/2 fuels
I've always believed it was improper to mix gas/fuel oil in same flue. Yesterdays inspection had both (fuel oil water heater/LP boiler) into same class A. What was odd to me, the boiler was installed in 1996 and had a county approved sticker on it.
Here's some pics. Also, check out the great beam cutting job!
John Springstead
Home Inspections of USA
1752 N.E. Torch Lake Dr.
Central Lake, MI 49622
1-231-544-8016 office
1-231-544-6001 fax
www.homeinspectionsusa.us
Old 2/13/08, 11:33 PM
rbrady's Avatar
rbrady rbrady is offline
Please Note: rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: One flue/2 fuels
I didn't think you were supposed to mix fuels either, but my codecheck book says "OK to vent gas & Oil to the same chimney" IRC 2426.5.6.2 UMC 809.0
Old 2/13/08, 11:54 PM
Paul A. Wozniak Paul A. Wozniak is offline
Please Note: Paul A. Wozniak is a non-member guest and is in no way affiliated with InterNACHI or its members.
Thumbs down Re: One flue/2 fuels
dear lord. did we fix this mess? haha
Old 2/13/08, 11:58 PM
i suppose codes are different everywhere, but here, you can have 2 different gas' in the same chimney, but not in the same flue. it must be 2 different entries into the chimney
Old 2/14/08, 1:07 PM
lolsen lolsen is offline
Years ago we tried to run a wood stove and a oil furnace in the same chimney. Insurance shut us down and made us put in another chimney. Again every area is different as is insurance companies.
Lawrence
Old 2/14/08, 1:37 PM
Peter Doane's Avatar
Same chimney OK, but into different flues,... most jurisdictions don't even allow two different wood burning fire places to expel into the "same" chimney flue. Check local codes.
Peter Doane
NACHI ID# 05120681
Old 2/21/08, 2:34 AM
Robert J. OConnor's Avatar
Wood stoves (and other solid fuel burning appliances) or fireplaces must have a dedicated flue per the IRC. However gas and oil equipment can share the same flue in many areas (e.g. per the IRC), although some consider it poor practice. Your local mileage may vary ...
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
Old 2/21/08, 7:18 AM
Rick K. Kie's Avatar
Rick K. Kie Rick K. Kie is offline
what about the furnaces that are Oil, Wood, and Coal with three different heatin chambers and one flue. With a heat exchanger for the water heater.
Old 2/21/08, 1:02 PM
Thats a special case where the equipment is designed/listed for common venting. But since it uses solid fuel it should not be vented in common with any other equipment (e.g. IRC M1801).
Robert O'Connor, PE
One flue/2 fuels jspringstead Inspecting HVAC Systems 0 2/13/08 10:20 PM
