Was infomed about an inspection that I performed last week the furnace was a 1984 model and My CO meter picked up a trace of CO which I documented in the report for an HVAC contractor to check and low and behold the heat exchanger had a crack. My client was a single mom on a lower end home and was just thrilled that she was getting a brand new furnace installed before close of escrow.
For you inspectors that have 26 pages of disclaimers and don't check furnaces in the summer months because it is to hot or you don't use CO meters you sure are missing some good advertising; nothing better than a happy client especially a woman that likes to talk in public places. </IMG></IMG> Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
Way to go, Charley!
It is a little tough to run the furnaces for 15 to 20 minutes in order for the potential cracks to open up, especially when there is no AC to cool the home back down, but worth it in the end. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Good job Charley.
Always nice to find deficiencies like that for a client. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Good one, Charley.
I usually run the furnace and water heater, together (especially if they vent to the same flue) to check for back drafting and CO. Ran into one, a couple of days ago that is typical. 1973 ranch, in pretty good shape. Replaced the furnace last year with an Amana cat 4, vented out the side with PVC. The water heater was also replaced (in 2003) and was still connected to the clay lined brick chimney. 93 degrees outside. My CO meter registered 7 ppm at the vent hood of the water heater (wonder what it would be if the temp outside had been 0 degrees?). Then ran into a big 'disagreement' with the agent. Explained that a water heater (conventional draft, 40 gallon, cheap a** GE) did not produce enough heat to warm the clay and brick. Hot air (including CO) goes up the flue, gets cooled by the clay liner (with the big ol' brick and concrete heat sink behind the clay), falls back and has no where to go but back out the water heater's vent hood. She didn't like that. But, I explained it to her AND the clients at the same time. Explain, clearly and understandably. That is the key. BTW: Realtor could not understand how the HVAC company could replace the furnace and not line the chimney flue to accomidate the change, with regards to the water heater. I did some checking, called the furnace guys and asked (I knew them). They stated that they explained the potential problem to the owner, back when they replaced the furnace. The client didn;t want to pay the extra $200 to have the chimney lined to accomidate the water heater BEING SAFE! The HVAC people made the seller sign a realease, stating that they had been made aware of the problem and were holding harmless the HVAC contractor for any CO back drafting. Also seemed that the basement CO dectecor went off, every now an then, during the winder months. They just took out the battery. They thought it was a big bother. The client was happy, though. Hope this helps; Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
| Someone invite the other Canadian Associations to this NACHI event on Wed please. | gromicko | Canadian Inspectors | 28 | 9/13/06 1:28 PM |
| Turmoil At The Top? | gluck | Canadian Inspectors | 34 | 9/4/06 8:07 AM |
