scosta is a non-member guest and is in no way affiliated with InterNACHI or its members.
Would you call this out as an open return?
Is there a code reference for this? I checked the Ohio Residential Code, and couldn't find one. Thanks, Steve |
Steve
Looks like a planned R/A plenum opening. Is the basm't area wide open and unfinished and/or does it have any S/A reg's. off the S/A ductwork. In the old days of my HVAC days we sometimes added a R/A and 1-2 S/A openings to unfinished Basm't storage type areas to temper the area and reduce the R.H. to a point that contents and framing and equipment would'nt freeze or sweat(condensation). Any of the above would be moot if any of the area has any earth floor or open crawl space area. Might want to ask a few questions or look at the area again to see if you pick up any other ideas as to a plan of design, Good Luck |
Greg,
Its on the unfinished side of the basement, along with the gas hot water tank, gas dryer, and a solid door seperating it from the finished side. I told them about combustion air requirements, but I also called out the return air. |
Don't know if its a code violation, but I think it is. I always call it out as being a safety concern though due to the possibility of effecting the natural drafting of the furnace and hot water tank venting, which can cause backdrafting of CO/fumes into living spaces. Recommend relocating to another room or area and blocking the offending vent off.
Darrell Hadler CMI Five Star Home Inspections Medicine Hat, AB. Canada NACHI# 04111082 Cell phone# (403)502-3593 Inspected once . . . inspected right! (website) http://inspectorpages.com/dhadler
You can not service two floors with the same unit unless there is a return and supply to all floors.
The extent of the efficiency of the installation will require a zoning system to control air flow. You can not heat and cool with the same duct system without a controller. I see all to many basement finishing jobs that just cut into the supply duct. Won't work guys! The heat/cool load in a basement is no where close to the first floor! At least they are pulling air that needs to be treated from the basement. The major concern is that the return air duct is within 10 feet of the furnace. That is a NO, NO! You will pull combustion gasses into the return and pollute the house. |
I totally agree with David no return even in the same room as the hot water heater That is worst than a return in the kitchen bacon smell through out the home or in a bathroom with you know what through out the home </IMG> Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
Steve,
Basically, it sounds like you are describing an enclosed Mech.Rm. area in the Basement. If that's the case, then my scenario above would be wrong and I think you did the proper thing commenting on the design/installation, especially on the combustion air and backdrafting concerns. |
Charlie, Miss me?
I've been working my ***** off! Things finally kicked in gear around here and I've been working 18 hours a day to keep up. My inspection got postponed this morning (thank God!). I was thinking of a way to postpone it myself when I received a voice message that the client got sick last night! |
Same here things went crazy impossible for an old man to keep up. Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
Yup no good
Joe Kormos A-1st Look Home Inspectors Inc. 630-201-0933 Your 1st Choice in Property Inspection Professionals www.a-1stlookhomeinspectors.com www.a-1stlook.com Let us look before you buy...for peace of mind “Thinking is the hardest work there is, that’s why so few engage in it. ” Henry Ford |
| something else to chew on | john bubber | Structural Inspections | 706 | 4/25/12 7:13 AM |
| gutter downspout to basement drainage system | David Paterson | Exterior Inspections | 2 | 12/18/06 6:27 PM |
| cold air return in basement? | bmargiotti | Inspecting HVAC Systems | 10 | 1/24/06 5:51 PM |
