Old 1/6/11, 6:25 PM
David C. Macy's Avatar
Default Open Window due to....
When I went around back I notice the window open and closed it. 25 degrees and snowing.
The sellers arrived with there agent and the opened the window back up. Heat was set at 80. (Good thing window was open)
When I arrived at the laundry/utility room and got a heavy wiff of CO I was glad the window was open as I was like a dog in a car grasping for air. The vent on the roof was rusted, the vent in the attic was transite and the section at the water heater was a joke.
I asked the sellers agent if the had the window open so they could live.
He said they had it opened due to them smoking. Never saw or smelled a cigarette the entire time I was there.
They called there HVAC guy and you can picture Sanford and Sons truck pulling up. I asked if this guy was repitable. He said he is the one that installed it. I said he should not be the one to fix it.
I still have a headache from the CO.
The entire vent pipe should be replaced in my humble opinion.
open-window-due-174911-023.jpg   open-window-due-174911-055.jpg   open-window-due-174911-0601.jpg   open-window-due-174911-095.jpg
Need a home inspection in Illinois? Check out InterNACHI's listing of Illinois certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/6/11, 6:43 PM
Michael Larson's Avatar
Default Re: Open Window due to....
CO- a colorless odorless, tasteless gas.
I'm glad you made it out OK.
Michael Larson
Hudson, WI
Old 1/9/11, 7:14 PM
sparksnmore sparksnmore is offline
Please Note: sparksnmore is a non-member guest and is in no way affiliated with InterNACHI or its members.
I can't believe that flue pipe was installed by a professional, most any DIY'er would do better. Micheal has a good point, Carbon Monoxide IS odorless.
Old 1/9/11, 11:29 PM
Brian E. Kelly's Avatar
Glad you are OK.
I always call out to replace Transite Vent Pipe.
The main reasons being Age, as they can have cracks that are very hard to detect. And Single wall Pipe is no Longer allowed in Attics, nor is it allowed to be butted up against wood framing anymore.
Old 2/22/12, 10:24 AM
Leonard Inkster's Avatar
Leonard Inkster Leonard Inkster is offline
Send a message via Skype™ to linkster
The plumbing doesn't look too hot either. Do they get much cavitation in the piping? Is it normal is the midwest to have the hot water line have a shut-off?
Future Proof Property Inspections
Leonard Inkster, CHI, IAC2
Proud NACHI Certified Member
Web: http://fppi.ca
Mail: leni@fppi.ca
oovoo: Len Inkster
skype: leninkster
facebook: Len Inkster
You can't depend on your eyes when your imagination is out of focus. (Mark Twain)
Old 2/22/12, 11:06 AM
Joe Funderburk, CMI's Avatar
It's not normal to have a shut-off on the hot water line anywhere. But the pipes weren't leaking. I wouldn't say anything about that.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 2/22/12, 11:20 AM
An HI An HI is offline
Please Note: An HI is a non-member guest and is in no way affiliated with InterNACHI or its members.
Having a shut-off on the hot line is an asset when changing out a tank. It keeps water from draining back from all upstairs lines. Notice thay have mechanical unions for the lines.
Old 2/22/12, 2:18 PM
Some plumbers install a valve on both pipes to avoid draining and refilling when installing a new WH.
At least that's they said...
Old 2/22/12, 2:53 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
For changing the tank every 8-10 years I don't think so! Here we have one shut off on the cold supply to work on the Hot water tank only.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 2/22/12, 6:01 PM
Bob Elliott's Avatar
Only reason for shutoff on hot side would be tandem units.
Old 2/22/12, 6:22 PM
Jeffrey R. Jonas's Avatar
"Not normal" just means "other than common practice". Nothing wrong with it, and in fact, is very common in North Central states or wherever Winterizing is utilized.
Old 2/22/12, 7:39 PM
Barry Adair's Avatar
hot valve is for the lady of the home
gets her point across without words
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
CPA of Health Canada reminding us of corded window coverings. gromicko Canadian Inspectors 7 4/23/07 7:31 AM
Replacing a double-paned window mmorgan Interior Inspections 24 3/2/06 10:09 PM
Window installation jmichalski Exterior Inspections 17 1/24/06 9:42 PM
