Old 2/24/10, 3:50 PM
Kenny Rigler Kenny Rigler is offline
Default Openings in Chimney in the Attic
Hey Guys-
Anyone have an idea on why they would have put these openings on the chimney in the attic? The chimney had 4 flues: 2 for separate fireplaces and 1 for the furnace/water heater. I wasn't able to tell what the fourth one was for and why they would have it open to the attic. From the outside, it's the flue at the top of the picture. Thanks.
Kenny
openings-chimney-attic-img_3317.jpg   openings-chimney-attic-img_3307.jpg   openings-chimney-attic-img_3214.jpg
Rigler Home Inspections
Hays, KS 67601
785-656-0272
Need a home inspection in Connecticut? Check out InterNACHI's listing of Connecticut certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/24/10, 4:54 PM
Bob Elliott's Avatar
Default Re: Openings in Chimney in the Attic
Maybe future flue plans or to assist mounting the clay tile liners?
Recommend re bricking.
Old 2/24/10, 6:44 PM
Probably for the same reason they ran the rafters through the chimney and failed to provide a cricket on the roof.
Old 2/24/10, 10:01 PM
Why not let the chimney help support the rafters...they probably thought it was a genius idea.
Do you write up lack of cricket? I looked closely because I figured there was a good chance of water penetration there but it was all dry.
Hays, KS 67601
785-656-0272
Old 2/24/10, 10:28 PM
I've see similar openings used for combustion air for the fireplace.
It does need a cricket, for sure.
Larry Kage, CMI
231 929 3525
Old 2/24/10, 11:51 PM
Banned
Who built that thing? In Canada, there must be a solid mass of masonry at least 12" thick between a chimney flue and any wood framing being supported by the chimney.
Hopefully, the flue with the opening is not being used........it does not have a full liner.
Old 2/25/10, 10:26 AM
Jeffrey R. Jonas's Avatar
Kenny,
(Side note)
Do you always traverse snow covered wood shingle roofs??? Man, you're just asking for trouble. Too dangerous. Stay safe!!!
Jeff
Old 2/25/10, 10:31 AM
Joe Funderburk, CMI's Avatar
Bread oven. Write it up for missing a door.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 2/25/10, 6:07 PM
Originally Posted by jjonas View Post
Kenny,
(Side note)
Jeff
Jeff-
I brought my sled along that way if I started to slip I'd just jump on that and have a fun slide off the roof . Only half of it had snow...I climbed up the dry side.
Kenny
Hays, KS 67601
785-656-0272
Old 2/25/10, 6:23 PM
Originally Posted by krigler View Post
Jeff-
Kenny
Funny guy!
Wasn't sure of your experience, and if you are a newer inspector, didn't want you to fall (no pun intended) into the trap thinking that you must traverse all roofs, as some would like you to think. Safety first!!!
Old 3/3/10, 6:51 PM
Joseph Hagarty,  CMI's Avatar
From what I can see of picture 3, there appears to be some type of a cricket looking at the flashing along the edge with the snow.
Flashing stepped higher in the center of the chimney.
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 3/3/10, 6:57 PM
Good observation Joe.
You are correct, that is why the flashing is step up in the brick coursing.
Good eye for a young fella.
Old 3/3/10, 7:01 PM
I think you are right.
Still, I don't like what appears to be a seam in the aluminum (?) flashing just below and parallel to the ridge...not much overlap...poor design.
Larry Kage, CMI
231 929 3525
Building Science- research from respected sources Brian A. MacNeish Ancillary Inspection Services & Additional Topics 17 7/12/11 6:31 AM
Mold question? ccurrins Interior Inspections 35 1/23/09 11:55 AM
What's Inside A Chimney mcyr Inspecting HVAC Systems 14 9/17/08 6:11 PM
Difficult Chimneys thance Inspecting HVAC Systems 2 1/29/08 8:16 PM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 8:10 AM
