I inspected a A/C system back a ways that had no 24 volt thermostat wires traveling to the outside unit. How can that be and it was operating.
There are several remote control units to make this work.
1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
Roy Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
How was the 220 run to the condensing unit? Sealtight? Could the LV t-stat wires been there? Not right, but nothing physically stopping them from being there.
I have seen the low voltage wires inside the electrical conduit.
Reported here, Colarado has gone wirless with phone and Computer in one part . Roy Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Charley,
I find thermostat wire wrapped (hidden) in the insulation around the refrigerant line. |
Charley,
Did you take the top/sides off the condenser and actually look inside? If so, and no T wires, I don't know what to tell you. |
Was it like one I saw once?
The ice truck loads a big block of ice on a rack and a big fan blows across it towards the duct to the house. No thermostat needed, the size of the ice block is engineered to cool the house to the desired temperature. |
That was for Bellewart Ice Company. I used to be the guy on the lower end of the saw but could not stand the cold so looked for another job . Roy Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
They call me the tricksters I get answers. An A/C unit that has no 24 wires to the outside unit is called a pump down unit and I do occasional see some in use. There is a liquid line solenoid valve located on the exterior side of the furnace A-coil that the Yellow wire or cooling wire activates this valve when the stat calls for cooling this valve is a normally closed valve that opens when the stat calls for cooling. In turn the outside condensing unit has a 220-volt contactor instead of a 24 volt contactor. One leg of the 220 volts is routed thru a low pressure switch back to the contactor. This low pressure switch is normally open. When the solenoid valve is activated for cooling and opens it allows pressure back to the low pressure switch that closes thus starts the compressor. No low voltage wires required at the unit. The thermostat operates the solenoid valve and the low pressure switch operates the compressor. </IMG></IMG> |
| Wires ran from lugs to auxilary panels | Kevin Luce | Electrical Inspections | 7 | 9/20/07 9:24 AM |
| What is a 'condenser' dryer ?? | rcooke | Canadian Inspectors | 9 | 9/9/07 7:02 PM |
| Loose/terminated wires in main panel | csteele | Electrical Inspections | 13 | 7/19/07 4:39 PM |
| Ground Wires Inside a Panel | mveitenhans | Electrical Inspections | 13 | 10/29/06 11:39 AM |
| Painted service wires | hcavin | Electrical Inspections | 1 | 9/27/06 12:47 PM |
