| HVAC Topics include heating, venting, and air conditioning. |
Soooooooooo
How do you guys go about testing one of these units? It is 80 degrees here and i am guessing i am going to have to throw some wood in her and fire it up? I have been procrastinating on going and educating myself on these but now is the time. I have an inspection tuesday with a exterior wood burning furnace. I plan on driving by the place tomorrow and finding out the brand and then go visit some local place or researching online or asking my brotherhood here. Let me know anything and everything. You can link me to something or email me at bishophomeinspection@charter.net or do it however you like! Thanks Andy B |
rramsey is a non-member guest and is in no way affiliated with InterNACHI or its members.
Inspectors do not light pilots or initiate power or fuel to appliances. Verify and test operation by controls only.
Are you going to take your chain saw to cut wood also? If so, please come by and test my firepalce; we need firewood for winter |
-look inside for warped fire chamber if it's steel- lot's of heavy use -look for signs of running creosote or heavy creosote buildup- may indicate an oversized unit run with low draft to "idle" while waiting for heat call. - wihout firing up check for pump operation and draft damper or fan operation by calling for heat - if chimney is accessible, check for creosote buildup |
Freedom Express Inspections LLC CMOR Thermography Certified Level 11 #2097 freedomexpressinspections.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F Professional Home Inspector State License # 130 Reporting system by Home Inspector Pro Serving the State of Okla. |
Personally, I would probably build a fire, do a load of laundry and hell, while Im at it, I could whip up a batch of Toll House cookies.
Doug Edwards, CMI |
Awesome info. I did think about it after and thought about just reviewing everything and trying to run the fan and also review boiler area like standard boilers.
Keep info coming. Can't hurt to be over educated! Thanks!!!!!!!!!!!!!!!!!!! |
-- Freedom Express Inspections LLC CMOR Thermography Certified Level 11 #2097 freedomexpressinspections.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F Professional Home Inspector State License # 130 Reporting system by Home Inspector Pro Serving the State of Okla. |
lol...you got it.
Doug Edwards, CMI |
| Hot Air furnace installed on wood floor | dbelmont | HVAC | 4 | 7/24/07 9:22 PM |
| Wood Burner and Gas Furnace No No's | bmargiotti | HVAC | 2 | 4/24/07 9:43 AM |
| Tech Links Page | bkelly2 | Structural | 3 | 1/11/07 5:18 PM |
| Wood Burning Furnace | dmacy | HVAC | 6 | 6/21/06 12:59 PM |
| Furnace flue how close to wood | abishop | HVAC | 13 | 5/30/06 3:15 AM |
