Hi guys...I am new to this post. Attached is a pic of an overheated AC disconnect. What would cause that? Should a breaker have tripped before this overheating occured? Can an AC unit be run if the air handler is off at the breaker?
| Need a home inspection in Idaho? Check out InterNACHI's listing of Idaho certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
The breaker in the panel may have been over fused. There should have been a maximum amperage listed on the label.
Obviously there has been a problem that needs to be addressed by a specialist. AND if the unit is functioning, it should be turned off at the breaker until it is fixed. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
That's a great pic. I looked it up and it said it was rated for 60 amps. How big was the breaker? I would guess it wasn't an issue of over current but and issue of a loose connection inside the disconnect that caused it to heat up.
Likely the plug was not properly or completely inserted resulting in the overheat failure. The rating of the device or the upstream breaker is probably not an issue; however, if the compressor locked up and the breaker feeding it did not trip, the result could be the same - not the situation if the unit was found to be running.
That's a good one. That's the kind of thing that a buyer would never notice until it was too late.
Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
The low voltage control comes from there. They are not on the same circuit though! Outside is still hot! "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
| Main Panel vs Sub-Panel and main disconnect? | rbassett | Electrical Inspections | 11 | 10/24/09 6:16 PM |
| A/C Disconnect question | rslocum | Inspecting HVAC Systems | 15 | 9/21/06 12:16 AM |
| 100 Amp Meter, 200 Amp Disconnect | jweinberg | Electrical Inspections | 8 | 8/15/06 12:32 PM |
| HVAC Disconnect | kgore | Inspecting HVAC Systems | 11 | 7/11/06 6:58 PM |
| Disconnect and Main panel | srowe | Electrical Inspections | 10 | 6/13/06 7:49 PM |
