Old 4/9/06, 12:31 AM
Joe Funderburk, CMI's Avatar
Default Oxidation on Copper Gas Line
Line feeds a gas water heater. Can anyone tell me the reason for this oxidation? If it was a water pipe, I'd know the answer. Thought it was unusual for gas.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 4/9/06, 12:32 AM
Default Re: Oxidation on Copper Gas Line
Should be in plumbing section. Sorry!
Theodore Roosevelt
Joe Funderburk, CMI
Old 4/9/06, 12:34 AM
Bruce A. King's Avatar
My guess is lack of proper cleaning after the soldering process.
www.BAKingHomeInspections.com
704 301-3207
Old 4/9/06, 12:36 AM
Jay Moge's Avatar
Jay Moge Jay Moge is offline
........or, if those joints aren't 100% gas tight, a leak will be present, propane and n.g. are realy realy cold when the run threw the pipe, and when they leak, condensation will occur and there's your moisture, maybe?
Old 4/9/06, 12:37 AM
Jay Moge's Avatar
i like that too, acid in the flux will cause the same thing sometimes.
Old 4/9/06, 2:39 AM
Russel Ray's Avatar
I like Bruce and Jay's answers.
Old 4/9/06, 6:55 AM
David P. Valley's Avatar
3/4 inch copper line for gas with joints???????? Wow....
You won't see that in my area. 1/4 inch copper tubing (with no joints) is the maximum I see in Massachusetts.
Is that piping legal in your area?
Maybe they should have used threaded black iron.
Old 4/9/06, 10:31 AM
Russel Ray's Avatar
I've never seen copper used for gas in any of the states where I have worked.
Old 4/9/06, 12:29 PM
Carla Horne's Avatar
Carla Horne Carla Horne is offline
I'm with David on that one.
that is a hazard waiting to happen!
Carla
Old 4/9/06, 1:53 PM
Copper tubing is a norm in the United States.
Here's some learning material for ya....
Attachment 2735
Old 4/9/06, 2:46 PM
Attachment 2735
Found this on that site: "In addition to mechanical joints, or in many cases instead of mechanical joints, brazed joints utilizing ASME/ANSI B16.22 wrought copper fittings may be used in copper gas distribution systems. When brazed connections are required, they should be made using a brazing alloy with a melting point above 1,000 F. The brazing alloy must contain less than 0.05% phosphorus."
So, do ya'll think the fittings are a concern? It's crunch time for me on this report.
Theodore Roosevelt
Joe Funderburk, CMI
Old 4/9/06, 3:03 PM
Russel Ray's Avatar
No.
Wow.
One cannot enter a simple No. on our new message board. Has to be at least 4 characters, and spaces apparently don't count as characters.
This new message board and its rules are, quite frankly, irritating and stupid in some cases.
Old 4/9/06, 3:09 PM
If this 3/4 inch copper pipe was on my inspection, I would be recommending a plumber to evaluate.
Old 4/9/06, 3:29 PM
Russel Ray's Avatar
I would also, not because of the fittings, but because it's copper tubing being used as a gas supply line. The plumbers here would be replacing the copper gas supply line with galvanized iron or black steel.
Old 4/9/06, 3:31 PM
Please tell me exactly why that is?
Theodore Roosevelt
Joe Funderburk, CMI
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 9:10 AM
Copper Line Fitting Richard Seay Plumbing Inspections 2 3/27/07 8:25 AM
Bathroom Shut-off Valves - Mineral deposits - Do you note them as leaking in reports? jwatts1 Plumbing Inspections 8 7/29/06 12:50 PM
TPRV line and condensate line marriage ccarrington Plumbing Inspections 3 4/29/06 8:59 AM
Looking for comment by Caoimhín P. Connell phinsperger Ancillary Inspection Services & Additional Topics 2 2/18/06 12:22 PM
