Old 6/20/07, 8:13 PM
Bruce A. King's Avatar
Default packaged gas unit
On a properly installed and operating gas pack with the heat mode operating, will you read/measure any carbon monoxide at the exhaust port on the unit using a typical CO tester?
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 6/20/07, 8:42 PM
Brian E. Kelly's Avatar
Default Re: packaged gas unit
I do not own a CO tester Bruce, but if the tester you own tests in the low ppm (parts per million) levels I would think you should get a reading.
Old 6/20/07, 8:51 PM
I get a high reading even holding it up 3 feet above the port.
I have a gas shop-type heater that shoots flames out 6 inches into a metal can that reads zero CO above it so I am thinking that CO is not a always present with gas burning applicances unless the burn pattern is disrupted.
704 301-3207
Old 6/20/07, 8:57 PM
Michael Larson's Avatar
Bruce,
I am not clear where you are taking the reading. Is this a flue stack reading?
I have a non-vented wall hung heater in my kitchen for supplemental heat and it reads "zero" on both of my CO meters. no matter where I hold the probe.
Heck CO is just always in the air here. http://www.azdeq.gov/environ/air/ozone/ensemble.pdf
Old 6/20/07, 9:00 PM
That's cause your downwind of CA.
Added for accuracy so as not to confuse others
Part of the use of a CO meter is to take a reading in an outside area that is not close to any known sources of CO such a traffic.
This provides a "zero" point calibration.
The other way would be to have a can on "zero" gas like I used when I calibrated lab instrumentation.
Old 6/20/07, 9:06 PM
Could you see the flame on the gas pack? Was it blue or yellow?
Old 6/20/07, 9:17 PM
I did not open it due to it being 14 yrs and the flames sounded like they were getting blown around in there. I bet it is a rust bucket inside.
704 301-3207
Old 6/21/07, 11:35 PM
Charley L. Bottger's Avatar
If you are talking the exhaust port as at the exterior of the unit the answer is most Definitely yes.
I can pick up .03 in a kitchen from a gas cook stove or a .07 from my Cigarette if I get to close If I don't brush my teeth my breath will set it off
</IMG></IMG>
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
New Geo unit neat system cbottger Inspecting HVAC Systems 14 4/14/08 2:48 PM
Need Assistance on A/C Unit pcarter-old-04 Inspecting HVAC Systems 9 6/21/06 7:23 AM
Adding a A/C unit abishop Inspecting HVAC Systems 20 1/18/06 1:39 PM
