Old 11/30/07, 5:56 PM
Michael W. Gault's Avatar
Michael W. Gault Michael W. Gault is offline
Default Painting the Gas Log Set vent termination
I don't think it's smart.
It says "Caution gets HOT" right on it, but I could not find it forbidden in the manufacturers installation instructions.
Thoughts?...
- Mike
Michael W. Gault, SC RBI 1728
A to Z Home Inspections
Charleston, Dorchester & Berkeley Counties in S.C.
NACHI05040682
www.atozinspector.com
(843) 442-9755
Charleston Home Inspector
Old 11/30/07, 9:09 PM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
Default Re: Painting the Gas Log Set vent termination
I saw this same situation 3 days ago. It was done by the building contractor. Haven't done the final for the new construction yet. Could use some input also.
Thanks
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Old 11/30/07, 9:17 PM
It's new construction with a CO issued yesterday... supposed to close Monday...
- Mike
NACHI05040682
(843) 442-9755
Old 11/30/07, 9:59 PM
Bob Elliott's Avatar
There are some high temp paints out there.
I am guessing this was not one of them.
Old 12/1/07, 12:37 AM
Michael Larson's Avatar
That would be a baked on finish.
Old 12/1/07, 7:54 AM
msylvester's Avatar
msylvester msylvester is offline
Send a message via AIM to msylvester
I at least have brought it to my clients attention and let them decide what action they would take. As Bob stated there are hi-temp paints.
I will say that the ones I find painted usually get replaced, unless the builder can provide info that the paint is OK for high temp and that the manufacturer allows it.
Mark Sylvester
P.I. Home Inspection Services
www.pihomeinspection.com
mark@pihomeinspection.com
Old 12/1/07, 9:31 AM
"No definitive answer on painting the vent termination for the gas log set (the manufacturers installation instructions did not say Not
to). I am unable to determine if the paint is an acceptable High Temperature paint which would be suitable for this application. Monitor for any problems while in use as it does get hot"
Sorry, Had to get the report out last night, but this is what I ended up putting in it....
- Mike
NACHI05040682
(843) 442-9755
Old 12/1/07, 10:39 PM
William J. Decker's Avatar
Smart, Mark.
Put the ball back in their court. Have them prove (in writing!!!) that it is right. You have no idea what they did and, frankly, it is not your jib to prove of disprove their work. Make them PROVE it.
That's what I do. I put it in the report and recommend the lawyer (or Realtor, if you are in an area that doesn't use lawyers for closings) do the nagging of the builder.
That's why they get the big comissions.
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 12/2/07, 6:15 AM
Barry Adair's Avatar
Why didn't the inspector fire up this unit during the inspection?
Paint bubbles, peels, scorches, catches the house on fire...FAILED UNDER NORMAL OPERATION
No more ifs, ands or buts...definative info and no further hypothesis or questions. jmo
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 12/2/07, 8:07 AM
Like I said, New Construction with a day old CO...
Log Sets are not normally hooked up (though they are provided) by the builder... They let an independent company do the connections and testing.
- Mike
NACHI05040682
(843) 442-9755
Old 12/2/07, 8:40 AM
Around here the FP/gas logs would have to be finished/fully operational by most munis before calling for final and issuance of CO.
better get
ADAIR INSPECTION
972-487-5634
TREC # 4563
Gas and oil hot water tank and Boiler Share Vents hvanderbeek Miscellaneous Discussion for Inspectors 8 1/25/07 5:22 PM
Vent termination thejnicki Plumbing Inspections 4 10/1/06 2:27 PM
Dryer Vent termination tneumann Miscellaneous Discussion for Inspectors 8 3/24/06 6:39 PM
vent termination ? bmargiotti Plumbing Inspections 7 2/18/06 9:42 AM
