Old 5/18/11, 9:39 AM
rhornung rhornung is offline
Default Partially Buried Oil Tank in Basement Question
Don't see too many oil tanks any more, this one seems to be empty but I want to give my clients a more accurate risk assessment and let them know how they should proceed. Am I correct is saying that if it is completely empty it should be no problem to leave it as is? The home is in Wayne, MI.
partially-buried-oil-tank-basement-question-p1430404.jpg   partially-buried-oil-tank-basement-question-p1430405.jpg
Need a home inspection in Missouri? Check out InterNACHI's listing of Missouri certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/18/11, 9:52 AM
Roy D. Cooke, Sr's Avatar
Default Re: Partially Buried Oil Tank in Basement Question
No way.... how do you know it has not leaked .
I would say they need immediate further evaluation by a qualified person .
I do know you can spend up to $300,000;00 or more here to have this removed and cleaned up.
Cover your but big time write hard .
Old 5/18/11, 9:57 AM
Jeffrey R. Jonas's Avatar
An eval of the tank and the surrounding soil should be performed. An empty tank (today) does not mean the tank or piping was not leaking in the past. All costs for clean-up of any contaminated soil is borne by the homeowner, and could run into the tens/hundreds of thousands of dollars. Your client must be advised of the potential risk, or you may be paying the bill.
Old 5/18/11, 10:23 AM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
The other factor is even if there is no leak the tank still has oil in it.
All the oil must be removed by cutting open the top and filling it with sand. A "Environmental Assessment" must be done to insure no leak has occurred under the existing tank.
No Insurance company will allow you to leave the tank AS IS.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 5/18/11, 12:53 PM
Jamie R. Wilks's Avatar
Jamie R. Wilks Jamie R. Wilks is offline
It would be a good idea for your client to contact the AHJ regarding this matter.
Some localities require the tank to be removed and any necessary clean up performed. Other localities allow the tank to be emptied or pumped out and then filled with sand or similar materials. The important thing to let your clients know is once they own the home they own the tank and any oil in it (and they are responsible for the tank and its contents from now until the end of time). You don’t need to be an alarmist, just advise them to check with the local AHJ and inform them about the future responsibility issues. Of course if the tank is leaking it would be a problem (I don’t think I would quote fees for clean up, remediation or removal).
Jamie R Wilks
North Star Home Inspections
VCHI #3380000351
InterNACHI #05081596
Old 5/18/11, 1:10 PM
David P. OKeefe's Avatar
David P. OKeefe David P. OKeefe is offline
This tank may not be completely empty. If it is, is it empty because it leaked out all the oil into the ground? I always tell my clients to have it further inspected, removed or properly decommissioned.
David
InterNACHI #08051301
NYS Lic. #16000038229
NYS DEC Cert # T4865884
518-505-8305
HouseAbout Home Inspections
HouseAbout on Facebook
NY Capital Region Chapter InterNACHI
Old 5/18/11, 1:25 PM
Matt Berman, CMI Matt Berman, CMI is offline
Thumbs down Re: Partially Buried Oil Tank in Basement Question
tank should be removed,soil tested,and if contaminated should be removed and new clean soil in its place. could be high dollar.
Old 5/18/11, 1:43 PM
tank should be removed,soil tested,and if contaminated should be removed and new clean soil in its place. could be high dollar.go to michigan.gov/deq
Septic System Care mlarson Ancillary Inspection Services & Additional Topics 52 8/31/07 10:26 PM
Basement Bathroom Venting Question Sean M. Jeric Plumbing Inspections 4 3/20/07 11:56 PM
Is this a competent asbestos removal job? Is our basement now a biohazard? David Paterson Ancillary Inspection Services & Additional Topics 5 1/16/07 7:16 PM
gutter downspout to basement drainage system David Paterson Exterior Inspections 2 12/18/06 6:27 PM
Expansion Tank Question cpetty Plumbing Inspections 9 9/25/06 7:13 PM
