Need help on age and capacity. This is a Payne heat pump, mn/pf1mnb030 / sn/0605a85635
Thanks "I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com |
I'd say it's the 6th week of '05
Mark
Would you know the capacity by chance? This is a heat pump, unlike btu's for a gas furnace, I guess. "I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com |
Gary,
Ditto 2005, it looks like it could be a 2.5 ton with the 30 in the model number. What was the square footage of the home? |
I agree.
2.5 ton manufactured in 2005. |
Mathew
It was aprox. 1800- 2100. Are heat pumps calculated the same way AC units are? "I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com |
The tonnage calculations remain the same. The heat pump and A/C systems are manufactured the same way, just the heat pump has a few more parts. The heat pump uses the compressor and back up heat to heat the home. Straight cool units use gas or electric heat strips to heat the home. Last edited by dvalley; 8/12/07 at 6:14 PM.. |
Thanks to all.
| HVAC age | tspeerstra | General Inspection Discussion | 11 | 3/7/12 8:25 AM |
| Age of Day & Night? | jweinberg | Inspecting HVAC Systems | 23 | 12/31/07 4:52 AM |
| Bryant age help | rcarter | Inspecting HVAC Systems | 4 | 10/14/07 8:55 PM |
| Payne and BelAire | abishop | Inspecting HVAC Systems | 0 | 1/22/07 9:16 PM |
| Payne Gas Furnace | jpope | Inspecting HVAC Systems | 6 | 9/7/06 8:58 PM |
