Found this document while researching a heat pump/air flow issue.
http://www.neo.ne.gov/home_const/airsource_heatpump.pdf |
| Need a home inspection in Pennsylvania? Check out InterNACHI's listing of Pennsylvania certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
thanks, I read it quickly and found a major error. The doc says heat pumps can only get heat from outdoor air down to 40 degrees then the heat strips take over. This is wrong, even the old heat pumps did better than that, the newer ones do much better.
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
My own unit that is 2 years old has a set point at 30 degrees. |
Bruce,
You are correct, I missed the error. |
Style Type Models VCSI Cooling Btu/hr Heating Btu/hr COOLING & HEATING ![]() ![]() Single Indoor Unit Heat Pumps Get More Details</SPAN> MSZ-FD09NA Y 2,800 ~ 9,000 3,000 ~ 18,000 MSZ-FD12NA Y 2,800 ~ 12,000 3,200 ~ 21,000 I have electric Base Board heatinh and last spring put in a MR.SLIM http://www.mitsubishielectric.ca/en/.../features.html I am pleased 22 seer 15 amp 21,000 BTU heat , 12,000 BTU cooling and it does main floor of our 1,800 bungalo Works down to about 10°F . I do not think we have used Electric heat more then 40 hours this year . Very quiet and does a great job Has Gas Fire Place in finished Basement of course some basement heat does come up stairs. Cost installed $3,200;00 Canadian 3 hours start to finish. Style Type Models VCSI CoolingBtu/hr HeatingBtu/hrCOOLING & HEATINGSingle Indoor UnitHeat PumpsGet More Details MSZ-FD09NA Y 2,800 ~ 9,000 3,000 ~ 18,000MSZ-FD12NA Y 2,800 ~ 12,000 3,200 ~ 21,000 Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
| Building Science- research from respected sources | Brian A. MacNeish | Ancillary Inspection Services & Additional Topics | 17 | 7/12/11 6:31 AM |
| Need Heat Pump advice | jfunderburk | Inspecting HVAC Systems | 6 | 2/5/09 10:41 AM |
| Heat Pump Question | waksell | Inspecting HVAC Systems | 13 | 1/19/07 10:02 AM |
| Heat Pump Check list for inspecting | dmacy | Inspecting HVAC Systems | 22 | 2/1/06 12:56 PM |
