| HVAC Topics include heating, venting, and air conditioning. |
This is a Trane furnace.
Please take a look at the picture. On the left side of the top picture you can see the large PVC pipes. My understanding is the one is to intake combustion air and the other is to exhaust combustion gases. In the second picture you can see that the two pipes tie together just before they exit through the roof. On the roof, there is simply an open pvc pipe that will allow rain water in. This just doesn't seem right to me. Am I missing something? Thanks!!! Mike Morgan Central Texas Home Inspections mike@centraltexashomeinspections.com www.centraltexashomeinspections.com |
In short, it appears that the intake/ exhaust terminate at a "concentric vent" kit. Any moisture should drain out through the condensate drain.
Typical concentric vent installation instructions:
http://www.htproducts.com/literature/lp-166.pdf http://johnsonsupply.com/york2001/PU...T/N2_4u799.pdf Last edited by mthomas2; 8/6/07 at 11:15 PM.. |
All pipe should flow back to the furnace. This includes rain.
Thanks all. I sure appreciate the info.
Mike Mike Morgan Central Texas Home Inspections mike@centraltexashomeinspections.com www.centraltexashomeinspections.com |
| High Efficiency venting????? | Matt Lewis | HVAC | 8 | 11/10/07 12:31 AM |
| 85% and 90% efficiency furnace | tvanvranken | HVAC | 2 | 5/17/07 9:50 AM |
| Furnace in attic (High Efficient) | jcordell | HVAC | 14 | 2/10/07 7:02 PM |
| High Efficiency furnace | rdean | General Inspection Discussion | 8 | 1/20/07 8:48 PM |
| Proper Vent - High Eff. Gas Furnace | rkuntz | HVAC | 8 | 1/13/06 11:18 PM |
