This is a 90+ yr house that had some plumbing upgrades. The house has a dirt crawlspace with no floor insulation.
The plumber ran PEX line out the walls into the living space and followed the top of the baseboard heat to another wall where he shot up to the second floor. In theory it works, but outside of theory, will the heating fins cause damage to the PEX or will it continue to work? The baseboard heat is active and works fine. Scott Falvey Clear View Home Inspections, LLC Newbury, NH NACHI#05051292 www.clearviewhomeinspectionsllc.com |
Hi Scott,
Personaly I would be concerened on 2 fronts, one being the freezing issue, the second being the fact that vibration between the fins and the tubing will lead to failures. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
The PEX is obstructing the convection air low through the fintube of the baseboard. I also notice there is no louver for adjusting the air flow in the picture. there is some minor expansion and contraction of the fintube as it heat cycles. Perhaps if the PEX were more carefully secured above the fins it would cause less problems. |
| Fetch Report problem | mhazelwood | Miscellaneous Discussion for Inspectors | 7 | 11/12/07 11:12 AM |
| Is MAC a problem | bemelander | General Inspection Discussion | 3 | 9/6/07 11:44 AM |
| Camera Problem | nwagner | Miscellaneous Discussion for Inspectors | 19 | 7/30/07 10:10 PM |
| Plumbing problem at home. | mnahrgang | Plumbing Inspections | 25 | 7/10/07 5:32 PM |
| Very tough problem | Albert Detorre | Inspecting HVAC Systems | 7 | 2/23/07 12:01 PM |
