Old 2/17/07, 5:54 PM
brepanshek brepanshek is offline
Please Note: brepanshek is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Propane gas to attic furnace
Here is the story... This home owner has 1 propane fueled gas furnace with a/c to heat the 1 floor portion of the home, then in the attic has a heatpump system to heat and cool the 2nd floor. Is there any reasons why the HVAC contractor would have put in a heatpump vs a propane gas furnace up in the attic also??? Does propane gas loose to much pressure going up 2-3 stories, possiblly why they didn't use gas here??? This home is only 2 years old. The client was asking this and was just wondering, give me your best thoughts.
Old 2/17/07, 8:13 PM
Charley L. Bottger's Avatar
Default Re: Propane gas to attic furnace
No the propane pressure is determined by the pressure regulator at the tank and is adjustable and could be piped to any level.
Most folks that I know perfer their bedrooms cooler than the areas such as the living room where substantial time is spent. My thinking would be these two different systems could be used to differentiate the cost of propane. But on the other hand I gave up years ago trying to guess what makes folks think. My thinking would be along the lines of cost of operation.
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 2/17/07, 8:22 PM
Marc D. Shunk's Avatar
Banned
Second floor systems often are much smaller (in capacity) than first floor systems, due to the fact that there is conditioned space below a 2nd floor and heat rises. It might have just made economic sense to use gas fired heating equipment for the heat load on the first floor and a heat pump on the second floor for the much smaller heating load. Might have also been an issue with venting, if the 2nd floor unit had no good place for receiving combustion air and do the flue venting. Might have also had to do with the cost of running the gas line to the attic. Just some guesses. This is a common installation, I should say.
Old 2/17/07, 9:04 PM
I've seen several such installations around here, but I never really gave it much thought why it was so. I'd just service the units and move on...
I have installed A/C units in the attic of houses with boilers, though.
Old 2/17/07, 10:08 PM
It feels good to know that others might say the samething as I woould. I don't know why I question myself so much? I stated almost word for word on what you said here Marc. I can rest peacefully now
Old 2/21/07, 6:06 PM
bbenjamin bbenjamin is offline
Please Note: bbenjamin is a non-member guest and is in no way affiliated with InterNACHI or its members.
Most heating and air companies can only install what the contract calls for in that specific home. Many of the builders that I have done work for install their units in this capacity one example would be Portrait Homes.
Horizontal Furnace in Attic Anthony Joseph Inspecting HVAC Systems 5 10/12/07 10:08 AM
Spray Foam to the Rescue ? mcyr Structural Inspections 3 3/27/07 8:29 PM
Condemned Furnaces Spark Safety Issues Gary Reecher Inspecting HVAC Systems 7 3/8/07 9:17 PM
Furnace in attic (High Efficient) jcordell Inspecting HVAC Systems 14 2/10/07 7:02 PM
Cat 1 Furnace in attic wdecker Inspecting HVAC Systems 2 6/14/06 2:28 AM
