Is this vent/air intake configuration proper for a high efficiency gas furnace?
NWJon is a non-member guest and is in no way affiliated with InterNACHI or its members.
Your picture is unclear... Are you refering to the ducting on the left or the white pvc on the right?... Where is this high efficient furnace in relation to the venting you are refering to...etc.? The pvc looks like a waste line or central vac piping. In this area .. we use black abs for waste lines.
Jon |
Ron:
May be OK if the install called for a concentric vent. http://www.alpinehomeair.com/viewpro...oodman_DCVK_20 Joseph P. Hagarty, CMI joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
Thanks |
Why is there wye in it? In my area pvc and abs are permitted. One line for combustion line, and another line for exhaust. Never have seen a wye.
Raymond Wand Alton, ON |
Goodman DCVK-20
2 Inch Horizontal/Vertical Concentric Vent http://www.alpinehomeair.com/viewpro...oodman_DCVK_20 Joseph P. Hagarty, CMI joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
Raymond,
Its a pipe within a pipe... double walled. So the exhaust venting is separate from the outside air intake. The wye separates them so to attach the proper pipes to the respective location on the furnace. Jon |
Thanks, that makes sense.
Dean Call is a non-member guest and is in no way affiliated with InterNACHI or its members.
Each make and model must be installed according to the manufacture's installation instructions that come with each particular unit. |
They should slope back towards the unit so condensation flows back to the unit and not freeze at the outdoor termination. |
| Vent for Electric Furnace?? | mlong | Inspecting HVAC Systems | 5 | 11/7/07 10:16 AM |
| Gas and oil hot water tank and Boiler Share Vents | hvanderbeek | Miscellaneous Discussion for Inspectors | 8 | 1/25/07 6:22 PM |
| Hart & Cooley plastic furnace vent | apfaff | Inspecting HVAC Systems | 2 | 8/15/06 4:20 AM |
| Exterior Furnace Vent Pipe | Steven Brewster | Inspecting HVAC Systems | 3 | 3/25/06 12:24 AM |
