Go Back   InterNACHI Message Board > Specific Inspection Topics > HVAC
HVAC Topics include heating, venting, and air conditioning.
LinkBack Thread Tools Display Modes
Old 3/22/07, 7:10 PM
Skip Erwin Skip Erwin is offline
Skip Erwin hasn't had much positive or negative feedback
Please Note: Skip Erwin is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default PVC for Flue
I ran across this natural gas furnace using PVC pipe for the exhaust flue. Is that OK? I don't normally see PVC being used for a flue. Thanks.
Old 3/22/07, 7:23 PM
Jason1's Avatar
Jason1 Jason1 is offline
Jason1 is headed towards a low reputation
Please Note: Jason1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: PVC for Flue
It's a high efficiency furnace.
Old 3/22/07, 7:25 PM
Jason1's Avatar
There should be one for combustion air as well....... Looks like it is missing??
Old 3/22/07, 7:27 PM
Jason1's Avatar
And don't let the contractor tell you it is ok, it should be drawing combustion air from outside.
Old 3/22/07, 7:30 PM
Jason1's Avatar
Are you a practicing home inspector?
Old 3/22/07, 7:42 PM
There is a vent in the floor. It's drawing combustion air from the crawlspace.
Old 3/22/07, 8:11 PM
Charles Buell's Avatar
Charles Buell Charles Buell is offline
Charles Buell is often very helpful Charles Buell is often very helpful
Not all High Efficiency furnaces draw there combustion/dilution air from the exterior. While you often see two pipes, it is not "always" the case.
Old 3/22/07, 8:55 PM
Jason1's Avatar
Only when the contractor wants to save 30 feet of pipe.
Old 3/22/07, 8:58 PM
Jason1's Avatar
High efficient furnaces are sealed combustion units, they don't draw from a vent. They draw from another pipe that should be beside the exhaust pipe, and run outside. Right now that furnace is drawing air from the room.
Old 3/22/07, 9:12 PM
dpeterson's Avatar
dpeterson dpeterson is offline
dpeterson has had a little positive feedback
Please Note: dpeterson is a non-member guest and is in no way affiliated with InterNACHI or its members.
From Goodmans Install Manual"
Dual certification means that the combustion air inlet pipe is optional
and the furnace can be vented as a:
Non-direct vent (single pipe) central forced air furnace in
which combustion air is taken from the installation area
or from air ducted from the outside or,
Direct vent (dual pipe) central forced air furnace in which
all combustion air supplied directly to the furnace burners
through a special air intake system outlined in these
instructions.
Old 3/22/07, 9:22 PM
Jason1's Avatar
instructions.
I still don't like it, I always recommend they be installed to the exterior of the home.
Old 3/22/07, 9:46 PM
Charley L. Bottger's Avatar
Charley L. Bottger .
instructions.
Atta Boy Donald good post.
CMOR Thermography Certified Level 11 #2097
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
Professional Home Inspector State License # 130
Reporting system by Home Inspector Pro
Serving the State of Okla.
Old 3/22/07, 9:50 PM
Personal choice should not enter into a home inspection its either right or its wrong no gray areas. An inspector could end of paying for the pipe if not careful??????
NACHI Member
Old 3/22/07, 10:27 PM
Jason1's Avatar
True, but I don't carry an installation manual for each manufacture around with me. So, IMHO it should be pulling from the exterior. To me it is just a workmanship thing.
Old 3/22/07, 10:37 PM
Some of the ones that I have seen that are allowed to draw air from the interior do not even have a place to install an intake pipe.
Display Modes
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
