| HVAC Topics include heating, venting, and air conditioning. |
The home was a brick sided house. How would you report the PVC vent in the chimney?
I feel it is a lazy installation. Didnt want to go thru brick. There is no way to cap chimney with vents. Also the flue was displaced & broken. Any comments would be appriciated. Dave |
I don't see a problem with running them up the old flue and I've seen them capped effectively too. I've seen where they cut holes in a solid cap at the top of the flue and where they've ended the pvc pipes below a pre made rain cap...they both looked and appeared to work well.
I'd just report that the newer pvc vent runs up the old chimney/flue and recommend a rain cap be installed. ____________________________________________ "An Education, not just an Inspection" Larry Kage Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector and Infrared Thermographer serving the Traverse City, Michigan area and beyond. ITC/FLIR CERTIFIED BUILDING SCIENCES THERMOGRAPHER ITC/FLIR CERTIFIED LEVEL 1 THERMOGRAPHER
Is that one vent or two? 1st pic. looks like two vents coming up, one with an elbow and one without. Anyway, one vent looks like it terminates vertically, where water and debris will enter the PVC. Not good if that's the case.
No requirement for a rain cap that I'm aware of, but I recommend them. Flue being broken is irrelevent if it's only used as a channel for the PVC flue. Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
| Chimney flashing photo's needed: brick and stone done correctly | kshepard | Exterior | 6 | 10/13/07 9:10 AM |
| Air admittance valves everywhere | apfaff | Plumbing | 13 | 4/16/07 10:17 AM |
| Vent in Chimney | pcarter | Interior | 6 | 3/13/07 2:56 PM |
| Gas and oil hot water tank and Boiler Share Vents | hvanderbeek | Misc. Discussion | 8 | 1/25/07 6:22 PM |
| Chimney vent | dmacy | HVAC | 2 | 7/31/06 8:33 PM |
