As I checked a central air unit today, I have a couple of questions. When I activated the thermostat, I went outside to check out the condensing unit. The compressor came on, and within a minute or two the high pressure line was very hot, the low pressure line was cool. The cooling fan did not activate. I shut it down after a couple of minutes. The unit was an Evco about 3-4 years old. Is this normal for the fan not to come on right away or begin to cycle? The compressor sounded like it was trying to prime itself, and then appeared to change rpm. I was told that it worked and that it has been operated this year. What say ye?
"He is no fool who gives what he cannot keep to gain that which he cannot lose." Jim Elliot 1949 Gerald Wilcox Harvey, ND CMIA, RMT www.housecheckhomeinspections.com www.homeinspectorinnorthdakota.com 701.324.4075 Minot, ND Home Inspections Devil's Lake, ND Home Inspections Bismarck, ND Home Inspections Jamestown, ND Home Inspections Home Inspector in North Dakota North Dakota Home Inspection |
The airhandler could have a bad capacitor for the fan motor.
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
You used the term cooling fan, to me that would be the indoor blower motor and I assume you are referring to the outside fan motor. Is this correct. Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
Yes, that is correct. I should have said the fan motor on the condensing unit. The compressor never kicked out, and I thought the unit smelled hot so I shut it down.
The fan should have started running this time of year at the same time the contactor pulled in even if there was a speed control or a head pressure control installed which was probally not likely. Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
Thanks Charlie, I think you hit the nail on the head! I could not hold my hand on the high pressure line for more than a moment, after only 2-3 minutes, and the ambient temp, was in the low 90's. I'll call it out as needing service.
By the way, if for the fun of it you wanted to know if it was the cap or motor, spin the blade with a screwdriver (not your finger). If the motor runs, it's the cap. |
Thanks for that info David
| Plumbing vent Routing Question | kweiss | Plumbing Inspections | 7 | 11/1/06 9:57 PM |
| draw inspection form question... | krea | General Inspection Discussion | 6 | 10/19/06 5:16 PM |
