Old 2/18/08, 4:25 PM
Bruce Thompson's Avatar
Bruce Thompson Bruce Thompson is offline
Default Readily Accessible Disconnect
I've been reading some posts on this mb and thought I knew what I was doing (thought!!)
My question relates to today's heat pump, but actually applies to any central heating furnace.
Can the breakers ON the unit be counted as the disconnect for the "appliance"? I'm looking at IRC 4001.5 table. Beneath the table is the line, "...permitted to be installed on or within the unit. It shall not be located on panels designed to allow access to the unit." Now obviously the mfr. installed these breakers.
So for the photo below, is another disconnect required? The breaker is at the lower left of the unit (behind the plastic panel). I know you all know that.
I have an idea, but I'm holding my cards close (so I don't look like a complete idiot).
Thanks in advance,
Bruce
Bruce Thompson
Professional Inspector, Lic. #9199
Serving Tyler, Lindale, Bullard, Whitehouse, Mineola and the surrounding East Texas area.
www.TylerHomeInspector.com
NACHI 06081394
Old 2/18/08, 4:49 PM
dbush's Avatar
dbush dbush is offline
Send a message via MSN to dbush Send a message via Yahoo to dbush
Please Note: dbush is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Readily Accessible Disconnect
Bruce, the realidy accessible breaker on the unit should suffice in most if not all jurisdictions. If it is not a code question, then it does suffice because it offers breaker protection without having to remove a portion of the equipment.
Old 2/18/08, 5:04 PM
It's not a code question. In my way of thinking (twisted granted), there is still power to these small breakers (even if off). I wouldn't want to work on the unit with electricity that close.
Thanks for the comments.
Bruce Thompson
NACHI 06081394
Old 2/18/08, 10:31 PM
Charley L. Bottger's Avatar
Bruce that breaker is perfectly fine. If one follows standard safety procedures such as using a meter to determine that the breakers actually turned off the power, not a problem. How I stayed alive long enough to retire was following safety standards. I never just assume the breaker was not burnt in the closed position before I stick my hands in there just common sense.
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 2/18/08, 10:34 PM
Thanks. I was hoping you would login and read my post. I appreciate it.
Bruce
Bruce Thompson
NACHI 06081394
Old 2/20/08, 7:53 AM
rgallahorn rgallahorn is offline
Be careful, on some AHU's the breaker only controls the heat strips and the unit has a second feed for the controls and fan assembly. Did this unit have 2 breakers behind the panel. It seems to have 2 feeds coming in at the base of the unit.
Old 2/20/08, 12:32 PM
It did have 2 breakers behind the panel.
Bruce Thompson
NACHI 06081394
Old 2/21/08, 3:14 AM
Robert J. OConnor's Avatar
Many of the heat strips I have installed on air handlers had one or two 240V 2-pole breakers with feeders for only the heat strip. The air handler typically needed a separate 120V feeder and disconnect.
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
New Washington Legislation Submitted gdomagala Legislation, Licensing & Legal Issues for Inspectors 293 2/10/08 2:20 AM
Home Inspection IS NOT ABOUT SAFETY jcahill General Inspection Discussion 39 2/26/07 12:08 AM
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 6:58 PM
Massachusetts Board of Registration of Home Inspectors jtedesco1 Legislation, Licensing & Legal Issues for Inspectors 0 2/14/06 4:38 AM
