Could someone explain to me about the red sealent.
What is it? I have seen the sealant before. I thought this application was sloppy. Is it really needed. It looks like ****. Thanks Dave |
bkelly1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
It is fire caulking.
So is it safe to assume that this was a homeowner attempt?
The same person that used a can of foam spray to try to stop a drain leak. Dave |
It looks like high temp RTV.
I think they need to use it up at the roof, from the looks of the water staining on the joist. |
tom |
I've seen similar sealant used in an attempt to seal cracks in a heat exchanger. It was described to me as a high-temperature sealant.
Red RTV gets my vote, if it feels rubbery 98% chance it is.
James R Lilly, CMIA www.lhiservices.com jamesrlilly@lhiservices.com Home and Mold Inspections Radon Testing Based in Parkersburg, WV Serving West Virginia and Ohio |
Red RTV
Gary Oleski Home Inspections Home Inspections Connecticut Connecticut . 06610 NACHI04012833 CT#HOI.341 C M I
bandag is a non-member guest and is in no way affiliated with InterNACHI or its members.
yes, around here it is called red rtv but it is not at home depot ( at least not the good stuff) it is only available at the plumbing supply to plumbers, (not sure why) I had some applied to my heating system.
| Wind-Smart Design | mcyr | General Inspection Discussion | 0 | 10/21/07 7:02 PM |
| caulking around vinyl windows. | rmc3inspection | Exterior Inspections | 11 | 10/12/07 4:24 PM |
| New sealant? | nbhi | Plumbing Inspections | 5 | 2/4/07 9:41 PM |
| Lintel sealant question | mthomas2 | Exterior Inspections | 4 | 10/23/06 6:16 PM |
