My inspection yesterday sent me into shock when I opened the furnace closet door there set the Heat pump A-coil directly on top of the furnace it was not within a enclosed box. The return air filter was in place approximately 2 feet above the coil simply slid into a built in slot on the 2X4 wall studs. The return air was bypassing the filter at the bottom of the closet door. What amused me the most was the owner had a wire brush lying near the coil to clean off the lint when ever they remembered to do it.
Every time I think I have seen it ALL something else like this pops up. I guess I won't live long enough to see it all. |
bandag is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hey Charley, What other redneck inventions did you find on that inspection? It amazes me the things people do that live way out in the sticks. Can't a service company find their address?
I also found a come-a-long holding the sewer pipes together had a nice baling wire strap made to connect the hook into and was trying to hold a 4 inch coupling together??? |
| Heat pump in a 80+ year old masonry house | jskrypka | Inspecting HVAC Systems | 9 | 11/25/06 10:47 PM |
| Carrier heat pump fires? | lprinzi | Inspecting HVAC Systems | 3 | 10/12/06 7:31 PM |
| Question on my heat pump | dbush | Inspecting HVAC Systems | 7 | 3/12/06 12:15 AM |
| Armstrong heat pump -- good or bad? | skipswift | Inspecting HVAC Systems | 3 | 2/13/06 9:17 PM |
| Heat Pump Check list for inspecting | dmacy | Inspecting HVAC Systems | 22 | 2/1/06 12:56 PM |
