Old 10/10/11, 10:28 PM
Jeffrey R. Pope's Avatar
Default Who to refer?
HVAC tech or sparky? Notice how nicely the thermostat wiring was attached to the box and routed through the sealtight (LFMC).
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Need a home inspection in Mississippi? Check out InterNACHI's listing of Mississippi certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/10/11, 10:36 PM
Charley L. Bottger's Avatar
Default Re: Who to refer?
Sure does keep the dogs from chewing the stat wire or at least they only do it once
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 10/11/11, 10:09 AM
Robert Meier's Avatar
Since it's an electrical violation I would say that a sparky would get the call to fix it.
Old 10/11/11, 10:25 AM
Jeffrey R. Jonas's Avatar
My company policy is to refer all electrical issues to sparky's, only.
You don't refer your HVAC issues to a carpenter, do you? (Although sometimes you probably should)!
Old 10/11/11, 10:32 AM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
I agree with Jeffrey Jones!
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 10/11/11, 10:42 AM
Originally Posted by kwood View Post
I agree with Jefferey Jones!
There's a first. I've seen it mis-spelled many ways, but that's a doosey!
Is that Canadian?
Old 10/11/11, 11:04 AM
I agree, but is this an "electrical" issue, or "HVAC" issue? After all, it's the thermostat wiring (HVAC issue) that will need to be relocated.
My question was more for fun (and Charley B's entertainment), but either call would be prudent. A qualified contractor of either trade can correct this issue, although I suspect the HVAC contractor was responsible for the original mistake.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 10/11/11, 11:06 AM
KEVIN WOOD's Avatar
Opps! Sorry Jeffrey Jones. FIXED
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 10/11/11, 11:14 AM
Understand and agree.
I posted my other thread for the same reason, but mophed into a serious thread on it's own. That's good though. Joke's go from being funny really quick when chit goes wrong.
In this case... as the wiring enters the disconnect box, I refer to a sparky.
If it did not, I would comment that a HVAC tech could repair, as it would only be low voltage and minimal risk.
Old 10/11/11, 11:15 AM
Better... and close... almost there...
Old 10/11/11, 11:21 AM
KEVIN WOOD's Avatar
Too many Jeffreys and too many last names!
JONAS JONAS JONAS JONAS JONAS JONAS JONAS JONAS JONAS JONAS JONAS JONAS JONAS JONAS JONAS JONAS JONAS JONAS JONAS JONAS
Are you happy now because if you are not you know where you can go!
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 10/11/11, 11:23 AM
Ha-ha-ha-ha!!! Yes... thank you, thank you very much!!!
Old 10/11/11, 4:46 PM
Yes I find a few of those my self surely it was installed by a sparky a Hvac guy just would not do that
NACHI Member
State License # 130
Old 10/16/11, 9:07 AM
Robert J. OConnor's Avatar
The thermostat wires (low voltage wiring) need to be relacated, which should be done by an HVAC specialist.
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
Old 10/16/11, 11:28 AM
David A. Andersen's Avatar
The trade that did it in the first place should be the trade to fix it.
Except: Bad disconnect installed by electrician, connected to the equipment by HVAC contractor; should be correct by the HVAC contractor as they allowed it's use.
BPI# 5015804
I need to refer Chattanooga TN Inspector rthoroman Miscellaneous Discussion for Inspectors 1 2/24/11 5:33 PM
what type of specialist to refer cwillick1 Structural Inspections 13 9/15/07 7:09 PM
Do you refer clients to Nachi to find an inspector? mroe Miscellaneous Discussion for Inspectors 1 8/21/07 12:34 PM
Need to refer a mold test in WI gliebig General Inspection Discussion 5 4/30/07 4:04 PM
