Old 11/14/11, 6:09 AM
John Gromkoski's Avatar
John Gromkoski John Gromkoski is offline
Default Refrigerant line question
Is there anything against using hard copper pipe with soldered fittings on the suction side of the AC refrigerant line?
774 Manor Road
Staten Island, NY 10314
718-514-3393
Need a home inspection in Nebraska? Check out InterNACHI's listing of Nebraska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/14/11, 6:52 AM
Wayne B. Wilson's Avatar
Default Re: Refrigerant line question
Depends, is approved for refrigeration? thick wall or did Billy bob use water pipe lol
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
Old 11/14/11, 1:02 PM
Robert Ernst Robert Ernst is offline
The soft copper line sets that are used are cleaned inside to prevent contamination of the system. Water pipe isn't prepared the same way. Plus with the rigid you will need more fittings and thus more areas for restriction and possible leaks. Soldering put contaminates inside the pipe and isn't as secure of a connection as brazing.
Nevada Inspector of Structures #1730
Nevada Energy Auditor #30
www.homecsi.com
Old 11/14/11, 2:32 PM
Doug Edwards's Avatar
these have different ID and OD than soft copper and as already pointed out not made to the same standards. I still find copper lines for gas used for plumbing with boogered up flared fittings and connections....always leaking
- John Stuart Mill
Old 11/14/11, 5:36 PM
Charley L. Bottger's Avatar
They sell hard drawn refrigerant tubing that is sealed with nitrogen it has rubber plugs in both ends
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 11/14/11, 5:39 PM
Yep all commercial lines are solid . I never ad a problem with corrosion
Wayne Wilson
865-256-1490
Old 11/14/11, 7:04 PM
Same here Charley, and all joints are silver soldered.
Old 11/14/11, 8:21 PM
Yes sir I used to cuss those dudes that used soft solder on suction lines it is allowed but a pain in the Butt when all yous have in your bag is silver solder the two don't mix
NACHI Member
State License # 130
Old 11/24/11, 10:14 AM
1107.5 Materials for refrigerant pipe and tubing. Piping materials shall be as set forth in Sections 1107.5.1 through 1107.5.5.
1107.5.3 Copper tube. Copper tube used for refrigerant piping erected on the premises shall be seamless copper tube of Type ACR (hard or annealed) complying with ASTM B 280. Where approved, copper tube for refrigerant piping erected on the premises shall be seamless copper tube of Type K, L or M (drawn or annealed) in accordance with ASTM B 88. Annealed temper copper tube shall not be used in sizes larger than a 2-inch (51 mm) nominal size. Mechanical joints shall not be used on annealed temper copper tube in sizes larger than 7/8-inch (22.2 mm) OD size.
and
1107.5.4 Copper tubing joints. Copper tubing joints used in refrigerating systems containing Group A2, A3, B2 or B3 refrigerants shall be brazed. Soldered joints shall not be used in such refrigerating systems
Paul W. Abernathy
and you all thought I only knew Electrical.....lol
Paul W. Abernathy
Old 11/24/11, 10:31 AM
Its been a while but I have changed out compressors in refrigerant units that the MFG used soft solder on suction lines. MFG always trumps ya code book
NACHI Member
State License # 130
Old 11/25/11, 6:46 AM
Aww..poopoo...lol.....follow the code and you can't go wrong. And atleast you will have the most unsafe home the code will allow...
Paul W. Abernathy
Old 11/25/11, 9:33 AM
I also wanted to respectfully disagree....lol....In accordance with Section 304.2 of the International Mechanical Code. Where there is a conflict between the code and the installation instructions or listing the provisions of the CODE shall apply. Now, where the code is less restrictive than the listing or manufactures instructions then you follow the listings and/or instructions.
However, the most restrictive will apply here so not always will the MFG trump the code book my friend....lol......Go..Guru...Go Shamu...i mean Guru !
Paul W. Abernathy
Old 11/28/11, 10:15 AM
Robert J. OConnor's Avatar
Only if it's not covered by the code or more restrictive than the code ...
Soldered refrigerant joints are now specifically prohibited by the code, so they cant be used if an IRC based code is in effect.
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
Old 11/28/11, 10:30 AM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
YEP! I have used that argument more than once Paul.
It could save some HI some much heartache and pain.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Gas line Cut-off question...pic dnasser Inspecting HVAC Systems 4 10/22/10 10:07 PM
Main Line vs. Supply Line Reporting Details sshockley Plumbing Inspections 2 6/14/09 3:07 PM
Selected Electrical Incidents and Occurrences - First Quarter pabernathy Electrical Inspections 0 12/2/07 1:43 PM
Supply Line Question hmcclard Plumbing Inspections 5 10/29/07 10:42 AM
Size of supply line aobrien Inspecting HVAC Systems 7 1/2/07 12:40 PM
