Can on you in the souther states that use refective radiant barriers in the attic spaces please tell me the reasoning behind using the barriers directly applied the underside of the roof deck?
I understand attaching the barriers to the underside of the rafters as that creates a vented air space. Or even using the double foiled bubble wrap stuff as effective methods. What I don't understand is something like if foil faced sheathing is used, how is the barrier suposed to reflect radiant heat back out when it is in direct contact with the deck sheathing? Reflective radiant bariers need a air space to be most effective do they not? |
http://www.radiantbarrier.com/physics_of_foil.htm
Not quite Brain. I read that same material already on a different site but I still don't see the answer to my question. How does the reflective barrier work when it is in direct contact (no air space) on the underside of the roof sheathing?
http://www.radiantbarrier.com/physics_of_foil.htm Quote:
Then why is foil faced roof decking being used in the south?
There are three types of heat transfer; conduction, convection, radiation.
They are three separate distinct means of transfer. Reflective substances reflect radiation. Contact has to do with conduction and is not related. Airspace is a very good insulator and prevents conduction from happening at radiation barriers. Airspace is not necessary for the reflective device to work, however adding an airspace will improve the overall construction of the wall/ roof /ceiling. Quote:
Maybe I'm just tired but I'm not grasping the concept you are communicating. |
So solar radiation comes from the sun and hit the shingles and converts to thermal heat in the shingles. That thermal heat is conducted to the roof deck because the shingles are in contact with the roof deck. The underside of the roof deck is face with aluminum reflective foil. Because the decking is in direct contact with the roof deck the foil also gathers thermal heat. Now here the tricky part. Because the foil has a very low emissivity (5%) the there is very little radiant heat leaving the roof deck into the attic area. So the attic is a bit cooler. Great. but what happened to that heat that would have normally been radiated into the attic? It stays a thermal heat in the roof deck and .... you guessed it. - the shingles. The shingles and roof deck are receiving 95% of the solar radiation hiting them ! That is a lot of energy cooking the shingles! |
Yes, I know it's them talking. Not you.
I just don't know what they're getting at. Part two: yes that is a lot of energy on the shingles! |
Thanks David.
Ted Frasco is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hello
It has been shown that the better application is placing the radiant barrier across the rafters and not the foil on the decking facing the inside of the attic. You are correct, you want airspace on the direction you want to reflect. We place across the rafters to block the radiant heat from entering the attic space to begin with and to reflect the radiant heat back away from the attic space. Some of the heat is vented out and most is just blocked from heating up the rest of the attic thermally. And no, the shingles are not damaged from reflecting the heat that is passing through them. For more information, read about reflective insulation at EcoFoil.com |
| Radiant ceiling heat? | bmargiotti | Inspecting HVAC Systems | 16 | 1/24/12 11:46 AM |
| IAC2 In new residential construction | mcyr | IAC2 Indoor Air Forum | 0 | 10/9/07 7:45 PM |
| About Air Barriers | mcyr | General Inspection Discussion | 5 | 9/29/07 11:10 PM |
