Slight corrosion observed near the bottom of the Nordyne air handler in a manufactured home. Would you recommend evaluation by a HVAC contractor. Appears to be have wicked up from the condensate pan.
| Find an InterNACHI certified Pennsylvania Home Inspector (and anywhere else in North America) |
No.
That's the condensate drain pan. In the summer there is water in it. That is no where bad enough to be an issue. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
Thank you David, that was my thinking but I do not see enough of these as it's been slow these past 2 years. This was also one of the cleaner units that I've seen.
I'd consider the rust on that evaporator coil to be pretty typical and having no negative impact.
Vince Santos
StepByStep Home Services LC (734) 748-9584 Providing Home Inspection Services to Southeast Michigan ITA Trained and Certified |
| Revision to NACHI COE - Item 6 | jbushart | Miscellaneous Discussion for Inspectors | 27 | 11/1/06 10:59 PM |
| Help Determining Reportable Service Size | cbarrows | Electrical Inspections | 8 | 7/19/06 8:12 PM |
