Can someone tell me where I might find the requirement that an "exterior" outlet be in the vicinity of the exterior ac units?
Thanks... |
| Need a home inspection in Iowa? Check out InterNACHI's listing of Iowa certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
There isn't a requirement around the unit. Exterior receptacles are required at the front and back of the dwelling.
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
Do you me the ac disconnect? If so it has to be within sight, I also believe within 50 ft.
Thanks guys, I found it.
210.63 Heating, Air-Conditioning, and Refrigeration Equipment Outlet. A 125-volt, single phase, 15- or 20-ampere-rated receptacle outlet shall be installed at an accessible location for the servicing of heating, air-conditioning, and refrigeration equipment. The receptacle shall be located on the same level and within 7.5 m (25 ft) of the heating, air-conditioning, and refrigeration equipment. The receptacle outlet shall not be connected to the load side of the equipment disconnecting means. |
I thought you said on the outside, not a crawl space.
That is exterior, usually very close to your ac units....
I simply note whether GFCI outlets are installed on the exterior of the home I'm in inspecting. I'm not concerned with outlets installed within a proximity of a condenser.
There is no requirement for one on the exterior near AC units. Only exterior receptacle requirements are on the front and rear of the home.
exception: A receptacle outlet shall not be required at one and two-family dwellings for the service of evaporative coolers. Jeff Jeff Wicklander Corwick Home Services Join my business on Facebook
Started in 1987 NEC 210.63 (bar by section) to current 2008 NEC 210.63
This requirement has been around for quite some time. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Strange. Just finished a new construction inspection an hour ago. Went past 4 homes that chose heat pumps instead of the gas furnace. Not one of them had a receptacle anywhere near the units. I also had a new heat pump install a short itme ago, with permit, at my son's house. The nearest exterior receptacle is on the far end of the home, probably 45 feet away. At first I thought maybe it is a regional thing but WA is using the 2008 NEC. Or maybe the AHJ just does not care......... imagine that. My bad.
As with any code, the local AHJ has the final word.
| TREC windows | jcahill | Legislation, Licensing & Legal Issues for Inspectors | 8 | 5/2/08 1:41 AM |
| Testing a dryer outlet | acox | Electrical Inspections | 14 | 7/27/06 10:51 PM |
| Massachusetts Board of Registration of Home Inspectors | jtedesco1 | Legislation, Licensing & Legal Issues for Inspectors | 0 | 2/14/06 3:38 AM |
