Did an inspection today where the air handler(heat pump) is located in an upstairs closet, with a solid door. There is a return duct stubed thru the floor for 1st floor return and a return duct stub thru the ceiling for second floor return. The air handler is an up draft unit sitting on a frame with no duct connected to the return.
This makes the closet one big return plenum, complete with pvc pipe, electrical, refrigerant lines, etc.etc..... Has anyone seen a set up like this before? I normaly call out when they run the drain line and refrigerant lines though a return duct. This just does not seem right. |
Duct systems are to conform with provisions of Manual D--and that does not include closets as plenums. Each AHJ may have a varying take on the subject, but most are fairly uniform on this.
It jes' ain't right! "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin |
| Return air from crawl space | WHI | Inspecting HVAC Systems | 11 | 1/9/12 7:43 PM |
| Reduced return air duct | mmorgan | Inspecting HVAC Systems | 4 | 6/6/07 7:39 PM |
| strong return? | mharrod | Inspecting HVAC Systems | 14 | 12/6/06 6:28 PM |
| Return air and water heater vent | jorbeck | Inspecting HVAC Systems | 5 | 10/9/06 7:42 AM |
| Cold air return and electrical romex | dmacy | Electrical Inspections | 12 | 1/3/06 6:16 PM |
