Old 7/3/06, 1:33 PM
lfoster's Avatar
lfoster lfoster is offline
Default Return air ducting through slab?
Looked at a house yesterday built about 1950, single story, that 'looked' like a concrete foundation.
One return air duct was located in entry hall near center of house, but in examination, the ducting traveled down appx. 2' below floor level and turned toward end of house where furnace was located. Looked into attic thinking they traveled the duct up in wall cavity, but did not find any evidence in attic.
Has anyone seen a full slab foundation with return-air ducting through slab, travel under slab, then through slab again to unit?
Thanks,
Linda
Old 7/3/06, 6:27 PM
Brian E. Kelly's Avatar
Default Re: Return air ducting through slab?
Quite common here in 1950's homes.
Old 7/3/06, 7:38 PM
James Eubank's Avatar
James Eubank James Eubank is offline
Send a message via Skype™ to jeubank
As a matter of fact, I ran into one of those setups again today, with plumbing in the slab, too. When I mentioned it to the buyer, she got very nervous. "What if the plumbing needs repaired or replaced, will they have to break through the slab?" she asked. I explained that a plumber could evaluate to see what the best repair method would be, and that it may or may not require breaking through the slab. I can understand her concern.
Certified Property Inspector
Home - Commercial - International
Love my family. Do the best quality of work I can.
Serve with compassion the orphan children of the Philippines.
Old 7/3/06, 9:26 PM
Under slab ducts can be a problem with moisture condensation, rust, mold, radon and other things. May require a closer look and replacement may be warranted.
Good idea to defer what you can't see.
Old 7/3/06, 9:54 PM
look at this, the home owner tried to fix damage and sale, the water was not on the disclosure.
return-air-ducting-through-slab-jsw_p1010159.jpg   return-air-ducting-through-slab-jsw_p1010165.jpg
Foundation w/return air ducting through slab? lfoster Structural Inspections 8 5/21/11 8:52 AM
Moisture in slabs mcyr Structural Inspections 7 8/20/07 7:33 PM
bbbb mcyr Structural Inspections 1 8/19/07 10:26 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 7:53 PM
supply in slab or walls? jeubank Plumbing Inspections 1 7/8/06 10:36 AM
