Old 10/11/07, 12:26 AM
W. Michael Chris's Avatar
W. Michael Chris W. Michael Chris is offline
Default Return found in garage
Found a return located in the ceiling of the garage today, but it was blocked off by a board which fit inside the grill and was painted black.
At first I thought they were heating and cooling the garage, but then I discovered the board.
Question (and I feel dumb for asking because I should know the answer, but I'm drawing up blank tonight - having a blonde moment) this is wrong, right?
Would appreciate any help with the write-up on this.
As always, thanks in advance for your help.
Mike Chris, Santa Clara, Utah
NACHI: #05051385
HouseNspect@gmail.com
www.housenspect.com
activerain
"A man's home is his castle . . . until the queen arrives."
Old 10/11/07, 1:04 AM
Dominic J. Maricic's Avatar
Dominic J. Maricic Dominic J. Maricic is offline
Send a message via ICQ to dmaricic Send a message via AIM to dmaricic Send a message via MSN to dmaricic Send a message via Yahoo to dmaricic
Default Re: Return found in garage
Wow!!! Is this a new construction? How could someone be so stupid to stick an air return in the garage where carbon monoxide is created? There's no way that a board is going to 100% prevent a gas from seeping inside the air return and into the rest of the house.
2008 InterNACHI Member and Innovator of the Year
HOME INSPECTOR PRO HOME INSPECTION SOFTWARE
NOW ONLY $499 ($15O OFF!!)
Easy to use, customizable Home Inspector Software that runs on Windows, Mac & Linux
InterNACHI members receive 3 months of FREE home inspector website hosting
List yourself in our Home Inspector Directory Free
Watch our NACHI.TV Software & Search Engine Optimization videos!
Help@HomeInspectorPro.com
Old 10/11/07, 1:07 AM
I found this: http://resourcecenter.pnl.gov/cocoon...r/article//130 which might help. At the end is this:
IRC 2000 Section M1602.3 and 2003, Section M1602.2 Prohibited Sources
The prohibited sources section allows for permanent openings between rooms in order to connect spaces together to meet a return-air location requirement: Item 4 prohibits return-air sources as follows: "A closet, bathroom, toilet room, kitchen, garage, mechanical room, furnace room or other dwelling unit." Item 5 prohibits "A room or space containing a fuel-burning appliance where such a room serves as the sole source of return air."
Not sure if this exactly what you need or not.
Old 10/11/07, 1:11 AM
Stephen W. Stanczyk's Avatar
Are you sure it wasnt an attic access. I saw something similar once and until I looked closely, I didn't realize it was an attic access for the garage. It seems that Harry Homeowner cut the hole to make an access for storage and used the grille to hold up the piece he had cut out. What will they think of next?
Stephen Stanczyk
Old 10/11/07, 10:35 AM
No, this was not new construction, unit was built in 1991, and as they say 'a little old lady had lived in the condo." Thanks for your response, last night I was so tired and couldn't think straight I forgot I had another photo showing the intake on this vent.
Thanks again, now that I'm awake and thinking better . . . (well, won't go there about thinking better) . . .
See attached photo . . . at least I was awake enough during the inspection to remove the grille and take out the board blocking, then got a piece of paper to see which way the air was moving and sure enough is was sucking in.
Thanks for your response, my first thought when I saw it was heating and cooling the garage (see that alot in my area with temperatures in the summer 110°F+), and my second was the attic access made by the homeowner. Deferring to an HVAC contractor to correct the problem.
Again thanks.
NACHI: #05051385
www.housenspect.com
activerain
Old 10/11/07, 10:39 AM
. . . and here I thought I was awake, posted the wrong photo . . . here's the intake photo.
NACHI: #05051385
www.housenspect.com
activerain
Old 10/11/07, 10:47 AM
Perhaps this was a model home, and the garage was used as a sales office? Last house like that I did had the return sealed properly. If only a plywood board is in the return with no sealant, CO and other fumes could leak around the board and into the home. I would write it up if not properly sealed off.
Abraham Lincoln
Old 10/11/07, 2:06 PM
jhugenroth jhugenroth is offline
Please Note: jhugenroth is a non-member guest and is in no way affiliated with InterNACHI or its members.
It's also a fire wall issue, even if the plywood board was sealed.
Old 10/11/07, 8:25 PM
Well it looks from the second picture like they didn't even bother to seal it. Someone's lucky the little old lady didn't die.
Old 10/11/07, 10:49 PM
Michael W. Gault's Avatar
Michael W. Gault Michael W. Gault is offline
Great guess... and the only real answer;
If it wasn't the model... someone HAS to be shot.
- Mike
Michael W. Gault, SC RBI 1728
A to Z Home Inspections
Charleston, Dorchester & Berkeley Counties in S.C.
NACHI05040682
www.atozinspector.com
(843) 442-9755
Charleston Home Inspector
Old 10/12/07, 1:33 AM
. . . Someone's lucky the little old lady didn't die.
But this is the reason I did the inspection, I'm told the tenant had past away, but I'm told she had been in a nursing home for sometime and the children are now selling off the condo.
NACHI: #05051385
www.housenspect.com
activerain
Old 10/12/07, 1:38 AM
That's very very scary. There's probably not much that can be done to go after a place built 16 years ago but if I was the owner I would at least file a complaint with the BBB.
Evaporative cooler in garage chellickson Inspecting HVAC Systems 9 7/23/07 1:08 AM
Garage ceiling & door header Al Barb Interior Inspections 7 3/27/07 1:07 PM
Garage Door Safety...No Reverse...Advice Please gliebig Exterior Inspections 33 3/17/07 8:28 PM
Garage fire rated wall jlybolt Interior Inspections 3 6/18/06 7:21 PM
