Old 1/2/11, 3:40 PM
Stephen P. Shockley's Avatar
Stephen P. Shockley Stephen P. Shockley is offline
Default Rheem Heat Pump Age
I came across the heat pump below yesterday and want to make sure I'm reading the age of the unit correctly, because I was told that it was the original unit that was put in when the house was built in 1990. I see this unit as being manufactured in 2000, which means it had to have been a replacement unit.
Rheem, Model No. RPNJ-031JAZ, Serial No. 6158 M2100 18568
Regards,
Steve
Shore-Footed Property Services, LLC
Stephen P. Shockley
MD Licensed Home Inspector
410-726-3471
Salisbury, Md
Need a home inspection in Nebraska? Check out InterNACHI's listing of Nebraska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/2/11, 4:37 PM
pnarron pnarron is offline
Default Re: Rheem Heat Pump Age
If it was a furnace it would be the 21 week of 2000. In the seral number the 4 numbers following the M are the week and year of mfg M2100. I will double check to see if that would be the same for the heat pump.
Old 1/2/11, 5:00 PM
Christopher Currins's Avatar
That's what I have too.
Rheem & Rudd: in the middle of the serial number will be a letter "F" or "M" the following four numbers are the week and year.
and here
Christopher Currins
Certified, Licensed
Old 1/2/11, 5:38 PM
Thanks. So it is obvious that this unit was replaced.
Regards,
Steve
Stephen P. Shockley
410-726-3471
Salisbury, Md
Old 1/2/11, 5:43 PM
Marcel Gratton's Avatar
That sounds about right, same for an AC.
On The Level Inspection
Gatineau, Québec
Radiant ceiling heat? bmargiotti Inspecting HVAC Systems 16 1/24/12 10:46 AM
Heat pump in a 80+ year old masonry house jskrypka Inspecting HVAC Systems 9 11/25/06 10:47 PM
Question on my heat pump dbush Inspecting HVAC Systems 7 3/12/06 12:15 AM
