Old 12/13/07, 10:40 PM
whandley's Avatar
whandley whandley is offline
Please Note: whandley is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Roof Mounted Combination Units
Guess how old these babies are?
Would you believe these American Standard units were manufactured in May 2004 and installed in February 2005.
roof-mounted-combination-units-2007-12-12_0880.jpg   roof-mounted-combination-units-2007-12-12_0881.jpg   roof-mounted-combination-units-2007-12-12_0881-small-.jpg.jpg
ID:	16678   roof-mounted-combination-units-2007-12-12_0882.jpg   roof-mounted-combination-units-2007-12-12_0897.jpg
Old 12/13/07, 11:05 PM
Michael R. Boyett's Avatar
Default Re: Roof Mounted Combination Units
Acid rain? Seriously, was this a commercial/industrial application that might have caustic emissions from inside or nearby?
Old 12/13/07, 11:18 PM
whandley's Avatar
Commercial/retail with no manufacturing of any type nearby. It is one block from the Ocean however. Heard from the HVAC Contractor that the American Standard Rep visited the site today. American Standard will be providing two replacement condensers for the combination units. Evidently an ocassional run of condenser coils make it out of the factory without proper protective coating.
Old 12/13/07, 11:43 PM
Charley L. Bottger's Avatar
Shucks that was going to be my question how close to the ocean.
Used to service a unit on the outside of a refinery control room south side was exposed to a process unit very toxic. Had to have the metal solder joints analyzed as the Ph would deteriorate in the joints and start leaking within two months of installation. The coils had to be be removed and a special coating applied to make the units last more than a year. Used to call the unit the training unit as we sent all of the pups down to practice soldering.
Management always stated air quality was fine but you could lay a brand new shiny copper fitting on the top of the A/C disconnect and within 24 hours it would be totally black.
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Building Science- research from respected sources Brian A. MacNeish Ancillary Inspection Services & Additional Topics 17 7/12/11 7:31 AM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 9:10 AM
Ice Gaurd membrane dmacy Exterior Inspections 36 6/14/07 1:21 AM
Roof Repair? Maybe NO jhagarty Exterior Inspections 9 2/15/07 2:19 AM
