Don't run into many heat pumps in the area of the country that I work and was wondering if the air conditioning side of a heat pump should be tested in the winter. Is there any potential damage that could be done by testing the A/C when the temperature is under 35 degrees?
| Find an InterNACHI certified Oregon Home Inspector (and anywhere else in North America) |
From the classes I have taken, it has always been recommended that you do not use a heat pump in AC mode if the temperature is below 65 degrees F.
Up here in the north I do not run any A/C equipment if it has been below 60 in a 24 hour period prior to the inspection.
Hudson-Mohawk Inspections LLC Ken Greene NYS license 16000041691 IAC2 Cert. # IAC2-01-6345 NY State Pest Technician: T5865955 www.hudsonmohawkinspections.com Last edited by kgreene1; 12/4/09 at 9:03 AM.. Reason: gramer |
What about a forced air system with a condenser?
same thing
Hudson-Mohawk Inspections LLC Ken Greene NYS license 16000041691 IAC2 Cert. # IAC2-01-6345 NY State Pest Technician: T5865955 www.hudsonmohawkinspections.com |
It's my understanding that you don't run it when the temp is under 65.
I have also been told that if the heat side works, then you can safely assume that the cold will also. I could be wrong, about this, but I think it just runs in reverse to cool. So that being the case everything should be fine if heat mode works. Also be sure to test the emergency heat mode as well. (That works more like an electric furnace.) Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
Maybe a little too simplified for a "test procedure". Heres some more info for those that need it. Some systems have programmed lockouts to keep the heat strips off unless its below a programmed set point outside.... The refrigerant line does not get hot immediately.... Many electric meters do not have any moving parts to observe during electric heat mode..... Many systems have a 5 minute delay when switching from heat to cool or vice versa........ B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
If it is 35, and you turn on the AC, how cold do you expect it to be at the registers????
Don't turn it on. |
I often turn on the AC condenser briefly just to verify that it will activate. I say this for air conditioners:
"We did not test the air-conditioning system thoroughly because the ambient temperature is too low, and testing it could damage the coil. However, we turned it on for less than 1 minute to verify that the condenser(s) would activate." I say this for heat pumps (no need to turn it to AC mode): "The heat pump(s) responded to a request for heat in normal mode, but was not tested on the cooling cycle because the ambient temperature is too low and to do so could damage the coil. But generally speaking, if the unit works in the heat mode, it should work in the A/C mode." “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Chuck Lambert is a non-member guest and is in no way affiliated with InterNACHI or its members.
Activation is not proper operation If there were to be a problem because of low ambient temps it would be immediately upon activation of unit. If there was a problem and one were to let it continue to run for a minute you just bought a condensing unit. Do some research of the major manufacturers some allow AC operation in low temp conditions down low as 40 °F. Most of the newer units allow operation well below the 65 °F mark. Chuck |
Chuck |
Sure, I know that. I was speaking generally. You are speaking specifically. I may modify my statement to say "...provided the reversing valve is functional." That would be better.
gkay is a non-member guest and is in no way affiliated with InterNACHI or its members.
Don’t run the heat pump in air conditioning mode in winter, it’s pointless and you are proving nothing. The only observation you can make when doing so is that the reversing valve is operational and even that observation is limited.
You can make the same limited observation that the reversing valve is operational by noting that there is no ice on the outdoor section which would indicate that the defrost cycle is operational and therefore the reversing valve. Even though the reversing valve operates you can't make any assumptions that the heat pump will operate satisfactory in air conditioning mode without proper heat loads and operating conditions. Mark it down as a limitation to the inspection due to low ambient conditions. I have seen heat pumps that appear to work satisfactory in heat mode but perform unsatisfactory in the air conditioning mode. Observations about heat pumps and air conditioners are very limited when it comes to home inspections due to the amount of information required to properly diagnose the equipment operation and the procedures and tools for collecting this information. Stick to the basics and operate heat pumps and air conditioners as they are designed to be operated under the correct ambient conditions. Although everyone knows what you mean when you say condenser coil and evap coil, Heat pump coils are more properly referred to as indoor coil and outdoor coil. This is because the reversing valve determines which is the condenser coil (heat rejecting) and which is the evaporator coil (heat absorbing). |
| Radiant ceiling heat? | bmargiotti | Inspecting HVAC Systems | 16 | 1/24/12 10:46 AM |
| Heat pump in a 80+ year old masonry house | jskrypka | Inspecting HVAC Systems | 9 | 11/25/06 10:47 PM |
| Question on my heat pump | dbush | Inspecting HVAC Systems | 7 | 3/12/06 12:15 AM |
| Armstrong heat pump -- good or bad? | skipswift | Inspecting HVAC Systems | 3 | 2/13/06 9:17 PM |
