This was a small carrier furnace MFG in 1992 and did not appear to ever have been serviced on a 300K+ home the right burner was over 1/2 buried in rust thus the orange flame incomplete combustion.
Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging Last edited by cbottger; 5/13/08 at 10:14 PM.. |
Where is this unit located in the house?
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Charley
Sounds like you may have a Combustion Air (C/A) problem, unless you've found a water leak (ie: vent, Evap.Coil pan, airflow/blowby, etc.) based on you locations. That's a problem that may start showing up in the new homes, in greater numbers, as the Building industry starts going to incapsulated/insulated Attics and Crawlspaces. There will probably be a learning curve/inspection problems as everyone works to get on the same page. I think in the mean time, houses will be built, inspections will be missed/errors made, and we'll be seeing the effects as H/I's down the road. What do you think? |
Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
Yep and it's the right chamber. They like to crack in the back on the right hand side where the chamber tapers.
I saw something very similar to this on a rental property I inspected. As a matter of fact it was the first home inspection I ever did for pay. The landlord called me and booked the inspection. The renters had moved out because the couldn't pay the bills. She said they claimed to be sick and couldn't work. But she thought they was just lazy deadbeats. As a new guy I didn't know exactly what I was looking at, but suspected something was wrong. I recommended a HVAC pro to evaluate the entire system. But knowing what a tight***** the landlord was, recommended strongly putting in a CO detector. Well she did and it went off, right away. So then she thought she got a bad detector, took it back to Walmart and got another. It went off to. The heat exchanger was rusted and cracked and putting Carbon Monoxide into the home. Lucky some people did not die here. I realized that day that how I do my job can be a matter of life and death. I am glad I learned that lesson early in my business.
| Inspection of HVAC by an area inspector. | dmcauley | Inspecting HVAC Systems | 13 | 3/21/07 11:03 AM |
| Another reason to recommend CO testers | rnewman1 | Interior Inspections | 2 | 10/12/06 7:47 AM |
