nrichards is a non-member guest and is in no way affiliated with InterNACHI or its members.
Can anyone tell me why this hood on water heater exhaust vent pipe is so rusty and what the solution might be. Thanks!
| Need a home inspection in Maryland? Check out InterNACHI's listing of Maryland certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
possibly to many elbows in vent pipe causing moisture to condensate and fall back down vent
Kisers Home Inspections http://www.inspectorpages.com/jkiser http://activerain.com/jimekiser http://www.kisershomeinspections.com |
Poor drafting possibly. Or, what is above that? Could be a blockage, causing condensate in there as well.
Missing rain cap?
How was the top of the other water heater? You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
arook is a non-member guest and is in no way affiliated with InterNACHI or its members.
I agree. Usually when you see rust on top of the water heater like that it indicates that the water heater is not drafting properly and allowing exhaust gases to backdraft into the house.
Did you try to confirm backdrafting? You can use a smoke pen to test for backdrafting. Did you take a carbon monoxide reading? Ultimately - not matter what the exact cause - "Heavy rust and corrosion noted on the top of the water heater and the exhaust vent for the water heater. This condition can indicate poor appliance drafting, although other or multiple problems may exist. Poor drafting can allow dangerous gases to enter the house. Safety concern. Recommend further evaluation by a licensed plumbing professional or other qualified professional prior to close of escrow." |
As the warm moist air rises inside the metal flue it cools (especially in winter), particularly if there are a lot of bends and elbows (or restrictions) or long runs of flue. The moisture condenses on the inside of the flue, collects along the interior sides and runs back down onto the top of the appliance. The flue gases also contains acid as a result of incomplete combustion, that too etches the metal, adds to the corrosion and significantly shortening the life of the unit. In short, sucky installations can and do damage to equipment, so don't do it.
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill |
Thanks to all for the quick and useful responses.
Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
Improper draft, lack of combustion air, mechanical room depressurizing need to get it checked out by someone that knows what they are doing.
I agree with the others; poor ventilation causing coorsive condensation of combustion gases to form and travel back down the vent pipe.
What is the diameter of the flue pipe, looks large, but it may just be the photo. Sometimes too large an exhaust flue will cause poor drafting. Jeff Tatlock BEACHSIDE Home Inspection Serving Satellite Beach, Indian Harbour Beach, Indialantic, Melbourne Beach, Cocoa Beach, Melbourne, Merritt Island, Brevard County, FL www.beachsideinspection.com/why_beachside |
That's insulated vent pipe. The large amount of rusting is from vent gas spillage. As said get it checked out. |
Yup!
Insufficient draft. Combustion gas is exiting outside the inner flue and condensing on the outer flue that is below the dew point temp of the combustion gasses. If I knew where you were from, I'd offer to swing by and do a draft test..... I'd even tell you why it was back-drafting... "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
I'm with Michael on this one, although a draft test with a match is definitely in order. www.MauiHomeInspections.com |
Match smoke is not a proper test. A draft gauge during system operation and operation of other devices such as furnace, kitchen and bathroom exhaust fans, clothes dryers etc. is the correct procedure |
What was condition of the rain cap and the rest of the venting? www.MauiHomeInspections.com |
| The Importance of Bathroom and Kitchen Fans | mkyriacou | Interior Inspections | 35 | 6/4/10 5:27 PM |
| Direct Vent Water Heater | mosburn | Plumbing Inspections | 2 | 9/20/08 2:57 PM |
| Rinnai Water heater vent | kelliott | Plumbing Inspections | 24 | 9/11/06 10:40 PM |
| Exhaust fan in room with gas water heater and furnace | jweinberg | Inspecting HVAC Systems | 7 | 2/18/06 1:23 PM |
